Pro 8120s Problem
  • mdfurqan2012
    • 194
    Pro 8120s Problem
    Dear All,
    I have 3 machines model pro8120s, one machine installed with fiery controller now we want o use its own printer controller so we install printer/scanner card successfully and get configuration page but when we connect it to network its internal NIC not responding i check SP5985 on board NIC and USB is enabled but NIC board not responding when we run ping command from computer it shows 'Destination host unreachable'.
    Kindly Guide me
  • 8T2
    • Aug 2015
    • 257
    Re: Pro 8120s Problem
    Not too familiar with the big machines but I'm pretty sure there should be a SP setting to enable/disable the fiery, should be in the service manual somewhere. Currently don't have access to download manual and check unfortunately
    Sent from my WAS-LX1 using Tapatalk
      • 37628
      Read your service manual. As part of the Fiery setup there is a SP settings that has to be changed. Return that SP setting to its default.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        +1 its in the service manual return to default.
        Regards Mark
        • mdfurqan2012
          • 194
          Thanks for the guidelines I done it successfully.
          Once again thanks
          • farhad
            • Apr 2020
            • 40
            hi
            you can download technical bullten for you machine
            if you read the technical bullten you can disable fiery on you machine and Continues by normal printing
            • mdfurqan2012
              • 194
              Originally posted by mdfurqan2012
              Dear All,
              Kindly Guide me
              So I resolved that problem.
              The on board nic is faulty so we connect this machine by option nic board use for connecting fiery controller when I removed fiery controller but not removed optional nic card and we connect machine to network by this card
                Originally posted by farhad
                hi
                WHAT IF HE DOESN'T HAVE ACCESS TO THE SITE?
                it has already been stated it's IN THE DAMN SERVICE MANUAL.!
                More useless info from a 0 rep power user.
                • anothertech
                  • 1771
                  I had no idea that you could print through the optional nic without attaching a Fiery to it. Good job, thanks for the follow up.
