Fuser MP 3054SP Reset
  • Tech18
    • Jun 2018
    • 23
    Hi All
    I got a new fuser film unit and it comes with a fuse to reset ..
    I can't figure out where to plug it ..
    Any ideas ..
    I wonder it go to this blue jumper ?
  • Coptech
    worker drone
    • 460
    Re: Fuser MP 3054SP Reset
    No. it does not go where the jumper is. It goes on the other connector. If you check the service manual on replacing the fusing film, it tells you which pins and which connector it goes in. If you manually reset the fuser count, you should not need the fuse anyway.
    • Tech18
      • Jun 2018
      • 23
      Oh, I thought The fuse is for resetting when it has over heat SC code ..?
      Didn't know it just for the counter..??
      BTW.. I don't have manual .. yet ..!!
      Thank you CopyTech
      • Coptech
        worker drone
        • 460
        There was one code in color machine that needed fuse to get to "level 2 reset". I suppose this one could be the same but have not yet run across needing it. A good reason to hang on to fuses in case that day ever does come I suppose.
        • Tech18
          • Jun 2018
          • 23
          Can you please upload the picture of that connector .
          I see only 2 connectors come out from the fuser ... must be the orther one ???
          I appreciate it very much ...
            • 37442
            Thank you CopyTech
            To clarify, if you are replacing the fusing unit because of a SC error code you need the fuse. If you are replacing as part of preventive maintenance, you do not. In either case you do need to reset the associated PM counter(s).
              • 37442
              If you have a service manual, it is clearly illustrated with pictures. If you do not have a service manual, you should not be working on the equipment.
              • Klydon
                • Mar 2009
                • 243
                It is a 2 pin connector inside the fuser. It is typically on the plastic piece where the plug that goes into the machine is and where the rest of the harness goes along. It most likely has nothing plugged into it at the moment or it may have a fuse in it already.
                As Slim mentioned, you should not need the fuse unless the machine is in a coded condition.
                • davel
                  • Oct 2011
                  • 1099
                  fuse.pdf
                  You only need to use fuse for SC544
                  • Tech18
                    • Jun 2018
                    • 23
                    Originally posted by davel
                    [ATTACH]45273[/ATTACH]
                    Yes, I'm aware of that
                    I got it
                    Thank you so much .
                      • 37442
                      If it were a color machine you would be correct but this is a B/W model.
                      Davel's attachment is the correct picture form the replacement portion of the manual.
                      • Tech18
                        • Jun 2018
                        • 23
                        There's no 2 pin connector on MP3054 ..
                        Look at the fuse picture i post
                        I know on other models have those
                        • Tech18
                          • Jun 2018
                          • 23
                          Comon .. i have been in copy field for 27 years .. most on Canon and others but not really Ricoh ..
                          I did literally rebuild this fuser unit in 5 minutes ..
                          I just need someone with manual and willing to help so i can see where the fuse go to .. that's all ..
                          Update ..: I got it
                            • 37442
                            Update ..: I got it
                            You haven't shown it in this thread.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              I got it
                              Thank you so much .
                              [ATTACH=CONFIG]45274[/ATTACH]
                              Update ..: I got it
                              The pictures are correct {bloody hell 5min to rebuild a fuser that fast 20min quicker than me
                              If you have a sc544 you will to also reset SP5-810-002.
                              Regards Mark
