Mp3555 scan to folder error
  • senakainoki
    • Nov 2019
    • 25
    [Error Code] Mp3555 scan to folder error
    Dear all,
    I have face problem with RICOH MP3555 Scan to folder. i already config with scan to folder. Once after scan message will showing error scan destination list cannot be used now.
    I have formed HDD. memory clear, But still the same error occurred. some one can help......Latest firmware has been updated.
    senaka
  • RMC8112
    • Nov 2019
    • 38
    Re: Mp3555 scan to folder error
    Check the SMBv2v3 firmware. Also are they using Windows 10?
    • ridgemill
      • Sep 2017
      • 180
      Make sure you have the following, or greater, firmware updated:
      Version 16.47
      Other changes:
      - Newly added SMBv2/v3 support.
      This firmware is dependent on the following firmware modules.
      Please be sure to update all of them:
      System/Copy v1.08 (D2895550L)
      Network Support v16.47 (D2895564G)
      Web Support v1.05 (D2895560F)
      Scanner v01.04 (D2895571F)
      Animation v1.03 (D2895562E)
      Please refer to the RTB(No.RGene095) for details.
      • senakainoki
        • Nov 2019
        • 25
        Version 16.47
        Other changes:
        Thanks,
        let me update firmware ..
        • anothertech
          • 1757
          Originally posted by senakainoki
          Thanks,
          You said that you already updated the firmware, so did you or didn't you?
