Ricoh 381-02
  • levantin
    • Aug 2019
    • 26
    Ricoh 381-02
    ricoh c6502 machine reported error 381-02. please help
  • hosennet
    • Mar 2007
    • 145
    Re: Ricoh 381-02
    SC381-02 Potential sensor output high error (C)
    • levantin
      • Aug 2019
      • 26
      Re: Ricoh 381-02
      Where is that potential sensor located?
      • hosennet
        • Mar 2007
        • 145
        Re: Ricoh 381-02
        • levantin
          • Aug 2019
          • 26
          Re: Ricoh 381-02
          [ATTACH=CONFIG]45323[/ATTACH]
          [ATTACH=CONFIG]45322[/ATTACH]
          Thanks very much. I'll check it out
          Thanks very much. I'll check it outThanks very much. I'll check it out
          • anothertech
            • 1771
            Re: Ricoh 381-02
            That is the location of the potential sensor pcb, not the cyan potential sensor.
            • sandmanmac
              • 3981
              Re: Ricoh 381-02
              Is there an echo where you are? where you are? where you are?
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Re: Ricoh 381-02
                Try cleaning 1st possible just may need full service
                Regards Mark
                • anothertech
                  • 1771
                  Re: Ricoh 381-02
                  If cleaning doesn't work, try swapping with magenta to see if the problem moves.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Re: Ricoh 381-02
                    1 + also pm life's
                    Regards Mark
                      • 37538
                      Re: Ricoh 381-02
                      It would help if you looked at the proper page of the Point to point. Electrical component layout (1/7). Cyan sensor is item 40.
