Ricoh mp7502 toner spill
  • edi1907
    • Dec 2015
    • 15
    Hello friends!
    I have a Ricoh mp7502 and it spills toner. I tried everything but I can't stop this. Especially in front of drum unit. I changed drum unit but nothing changed. Anybody help me please?
    Imgur: The magic of the Internet
  • davel
    • Oct 2011
    • 1104
    Re: Ricoh mp7502 toner spill
    What volume? Clean everything. Replace all PM parts that are due. Check seals on dev unit and drum unit.
    • anothertech
      • 1769
      D131-08.pdf
      Try the tips in this tech pub, hope it helps.
        • 37489
        Since you said that you changed the drum unit makes me suspect that you might have meant to type MP C7502.
        • mikadonovan
          • May 2008
          • 2931
          Easy fix, this base model has been around forever. Dirty ID sensor, clogged/dirty filters, an an improper developer set will cause what you are seeing. Obviously a worn drum and charge wire will also contribute to dusting and overtoning.
          NEVER ASSUME ANYTHING
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Hi slimslob it is a mp series pic's on 1st post
            {STAY SAFE}
            MARK
            Regards Mark
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Originally posted by anothertech
              [ATTACH]45327[/ATTACH]
              +1 follow this information a must do filters please try not to use used dev unit if it's needed
              Regards Mark
              • skinnyb
                • Jul 2008
                • 291
                I agree. Full pm (300K kit at least which includes all filters, CRITICAL) P/N PMD131300K, vacuum down, check developer seals and change developer B0649640. Pay particular attention to the toner recycler unit on top of developer unit (toner hopper part), if it clogs up it will back up and cause it to spew toner out like this. At the very least take it apart and vacuum out. Good luck.
                Sent from my LM-V405 using Tapatalk
                  • 37489
                  Originally posted by skinnyb
                  I agree. Pay particular attention to the toner recycler unit on top of developer unit (toner hopper part), if it clogs up it will back up and cause it to spew toner out like this. At the very least take it apart and vacuum out. Good luck.
                  Since it is not in any PM kit it often gets ignored. The maintenance tables recommend replacement at 600k. Somewhere between 600K and 900K the Mylar flippers will come lose and the foam seal on top will start to disintegrate. When scheduling a PM check the part counter for it and if over or near 600K, order a new one.
                  • SeanMN
                    whats the humidity like? I have a hell of a time getting my seg 5s to run clean in the winter in Minnesota. April-Oct they run fine but as soon as winter hits and furnaces are running and we are at 10-20% humidity these machines just don't run well, 50-60k before developer is shot and toner is all over like in the pictures. Noticed at accounts with <20% humidity it is not as bad of a issue.
                      • 37489
                      Humidity Range:
                      Recommended: 30% to 70 %RH
                      Many machine also specify non condensing. Regardless of the humidity, condensation in the drum and development unit and on the paper can be devastating.
                      I have found cold overnight temperatures to be more a problem than humidity. Have you considered the anti condensation heaters. The drum and tray heaters should already be installed and just need to be connected to the PSU. Look in your service manual.
                      I have also known techs with customers at high altitudes to place pans of water under or in back of the machines to add moisture to the air. High altitude plus low humidity can equal static and corona units arcing.
