Lanier MP C2504ex Toner Blasting
  • Hoosierdaddy
    • Oct 2016
    • 182
    I have a problem with it spraying toner like the 03 Series machines were doing. I havent seen any bulletins on this series of machines for this issue. It will say the toner cartridge isnt set I take it apart and clean the toner contact board and vacuim out the area around the toner hopper. Updated the firmware but it still comes back after a few weeks. Anyone have issues like this with this series of machines?
    Thanks for any help
    Stay safe and Healthy my Friends
    Hoosierdaddy
  • 8T2
    • Aug 2015
    • 257
    Re: Lanier MP C2504ex Toner Blasting
    Your PM parts up to date? Very low yields on the 2004 and 2504
    Sent from my WAS-LX1 using Tapatalk
    • Codex
      • May 2008
      • 704
      Had same problem with a Mpc2004, change toner hoper... Toner stucks inside the hopper
      Inviato dal mio SM-G935F utilizzando Tapatalk
      Memento Audere Semper
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        1+ on Codex. The METIS-20ies have another toner then the rest - the hopper get clumpsy, cleaning last not very long often broken parts.
        Greetings...
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          +1 also don't use cheap toner and check transfer cleaning and waste
          Regards Mark
          • copier tech
            • 8176
            Thanks for any help
            Hoosierdaddy
            There's two different solutions for a similar issues.
            Toner not set or toner empty
            Toner not set is either a faulty toner cartridge RFID chip or the BRB pcb in the machine.
            Toner empty is either a failed developer unit or toner hopper.
            • FrohnB
              • Jul 2017
              • 1919
              Thanks for any help
              Hoosierdaddy
              What color toner is spraying? Or is it all of them?
              If it's yellow all over, then your issue is probably the ITB unit. Roller on the left side that sits almost above yellow drum has bushings that get egged out, and that roller sits lower than normal and "pulls" toner from the yellow unit onto the belt.
              Omertà
              • Hoosierdaddy
                • Oct 2016
                • 182
                It is the Black Unit I only use OEM Toner
                Thanks Hoosierdaddy
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Thanks Hoosierdaddy
                  Replace new oem Black dev assy think its pm is 120k
                  I would do pcu and dev assy and set as new unit so will setup properly
                  And give the machine a got vacout also clean id sensors
                  Regards Mark
                  • mikadonovan
                    • May 2008
                    • 2931
                    Originally posted by mga
                    clean id sensors
                    This is one thing that is not mentioned enough on the forum. Cleaning the density sensors will solve many CQ issues, including overtoning. It should be the first thing a tech does before digging into the other possible causes.
                    NEVER ASSUME ANYTHING
