Ricoh Aficio SP C221 SF / 1.72 Firmware update
  • teoadams
    • Mar 2020
    • 12
    Hi, I'm trying to update firmware to v. 1.72 but I always get this message: "Can't open Bootloader file. Please check Bootloader file."
    I have tried USB and Ethernet connection with the same result; I have tried Windows10, Seven and XP with the same result.
    Thanks for any suggestion
    Teo
    • 37550
    Re: Ricoh Aficio SP C221 SF / 1.72 Firmware update
    My guess is the update file got corrupted during download. Download it again.
      maybe he didn't extract the files properly? not on the root of the USB?
      • teoadams
        • Mar 2020
        • 12
        Hi Phil, thanks for suggestion.
        Already tried to re-download and not to self-extract but open with winrar but the original file from Ricoh is not corrupted and does't lokk to miss something....
          where are you extracting files to?
          how are you attempting to update?
          please list all steps you are using?
          how do you know files aren't corrupt?
          where did you get the files?
          • teoadams
            • Mar 2020
            • 12
            1) Extracting files to c:\v1.72
            2) Downloaded from: Aficio SP C220S/C221SF Downloads | Ricoh Global
            and from: SP C220S/C221SF download page
            3.1) launched self extracting downloaded file z88959L10.exe
            4.1) launched UpdateTool.exe (with and without admin privileges)
            5.1) tried with F/W Update (NET) and printer IP address and got error message
            6.1) tried with F/W Update (USB) and printer IP address and got error message
            3.2) opened downloaded file z88959L10.exe with winrar and manually extracted to c:\v1.72
            4.2) same as 4.1
            5.2) same as 5.1
            6.2) same as 6.1
              4.2) same as 4.1
              5.2) same as 5.1
              6.2) same as 6.1
              files should be on root of USB stick not on PC c:\xxxx
              are you following the SM for your procedure ?
              • teoadams
                • Mar 2020
                • 12
                From the attached pdf manual installation directory can be on c root
                What do you mean with SM?
                  NUFF SAID.
                    • 37550
                    Did you attempt to update with the fresh download?
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      As this machine has been discontinued for a long time now there is a 2020 main firmware only on my ricoh I should think this now could only be done by engineer not end user via control panel information would be in the engineer service manual
                      Regards Mark
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        You could Always thy posting a thread on service manual forum someone maybe able to help good luck
                        Regards Mark
                        • teoadams
                          • Mar 2020
                          • 12
                          This is also possible but from the pdf guide it seems to be a normal firmware update
                          • teoadams
                            • Mar 2020
                            • 12
                            Yes with the same error
                            • teoadams
                              • Mar 2020
                              • 12
                              I'm not expert in this firmware structure but from all the attemps I tried to do it seems to me that this unfound bootloader file could be on the machine's ROM...
