Ricoh 3053, 3054 no print scan
  • ameritech
    • 96
    Hello everyone, we have Ricoh 3053, 3054 with no print/scan option. I believe these do not need sd to enable function. We reset, update firmware still no luck.
    Has anyone seen this. Thank you.
    • 37556
    Re: Ricoh 3053, 3054 no print scan
    By this do you mean that the functions do not appear on the Home screen or that they do not appear in User Tools or SP mode? If they just do not appear on the home screen, you need to enable them, I believe in SP, and add them to the screen in User Tools and assign them a function button to access them from other functions without have to return to the Home screen. If they are not available in User Tools or SP, you might have cratered the control board.
    • ameritech
      • 96
      Thank you for the confirmation. There are no option in User Tools or SP mode.
      • copyaction
        • Oct 2007
        • 991
        Was the HDD removed?
        • ameritech
          • 96
          Hard drive is still present in machine. Thank you.
          • CopyBats
            • Aug 2011
            • 147
            Make sure your NIC card is turned on. SP 5-985 set it to 1. This is the setting to get the scanner working. Restart the machine or do a soft boot for the settings to take effect.
            If it works, don't touch it.
            • FrohnB
              • Jul 2017
              • 1919
              +1 on this.
              Omertà
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Have a mp3053 or MP3054 no sd card needed on later models
                Regards Mark
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  +2 on this
                  Regards Mark
                  • ameritech
                    • 96
                    I verified SP 5-985 set it to 1, there's only system sp under service mode. Thank you.
                    • anothertech
                      • 1771
                      I would try a new hard drive, if still no good then controller PCB.
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        I would now try
                        Backup address book
                        Format hdd all in service mode
                        Clear nvram all BUT NOT 1 & 2
                        reboot machine
                        Regards Mark
                        • CopyBats
                          • Aug 2011
                          • 147
                          3 options that may be causing it .
                          1) If the machines were previously used with a fiery GW controller may be off.
                          Change the setting of SP5895-002 from "0" to "1".
                          2) Corrupted / defective hard drive. Format the HDD . Or it doesn't work swap with a hard drive you know that works
                          3) Defective Controller possibility
                          • davel
                            • Oct 2011
                            • 1107
                            Please confirm mode,l is it 3053 or 3054, they are completely different machines.
