Mp c4504 java update problem
  • hosennet
    • Mar 2007
    • 145
    Hi all
    Looking remote install manager for java vm v12 edc.ifu update
    Help me please
    Best Regards
  • zoor
    • Jul 2019
    • 26
    Re: Mp c4504 java update problem
    No remote firmware update available, only by SD Card
    • hosennet
      • Mar 2007
      • 145
      How to update java vm v12 (file : D2415579W_edc.ifu)
      • Zeldaman
        • Mar 2011
        • 946
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          +1 only by sd card it's in the service manual
          Regards Mark
          • anothertech
            • 1771
            Were did you get that edc.ifu file?
            I think you are correct in saying that you need Remote Install Manager to use that file to update java remotely.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              I think you can only update java from sd card not remotely I've looked on my ricoh and under java firmware there only manual download available in the uk. Unless it's done with @remote but not sure if you can I will look into this
              Regards Mark
              • anothertech
                • 1771
                It can be done with Remote Install Manager on some machines, I am not sure about this machine, but I'm assuming it can be because the original poster here has the D2415579W_edc.ifu file. That is the type file that Remote Install Manager uses.
                I found the Remote Install Manager at the Ricoh
                http://rfg-esource.ricoh-usa.com/ site.
                I don't want to be misleading, I have never done the java remote update myself, but I have had tech support here in the US do it while I waited onsite, just not on this model.
                  • 37507
                  I think the point here is that they did it while you were at the machine to make sure that nothing went wrong at the machine.
                  • anothertech
                    • 1771
                    Yes, I had replaced the hard drive and they were going to reload Streamline remotely, but first they wanted to update the firmware and java, which they did remotely. I took quite a long time for everything to load.
