[Ricoh SF C222SF] SC543 error and trouble accessing maintenance mode
  • bloodorange
    • Apr 2020
    • 3
    [Error Code] [Ricoh SF C222SF] SC543 error and trouble accessing maintenance mode
    From a quick google search, I'm found that the SC543 error means that a thermister has been overloaded and I need to either:
    - reset it in the printer, or
    - replace the thermister and then reset it in the printer
    I looked at a few posts around the internet and the general consensus has been to go to maintenance mode and reset the fuser (or something to that effect). I found this post -> Aficio SP C222SF SC543 error. I have tried all sorts of commands to set into service mode to clear this and I have not
    that suggested for a C220 model (and by extension, my C222 model) do the following:
    Press the red CLEAR/STOP key till you hear the little beep.
    Press 1 0 7 then Press the green COLOR START key.
    The display changes into MAINTENANCE MODE
    Use arrow keys to go to ENGINE MAINTENANCE and hit Ok.
    Use the arrow keys and select FUSER SC RESET and hit Ok
    Hit OK again at the Execute prompt.
    Once it is done executing the reset, power the unit off and on
    I tried doing this on my printer buttons (Printer - Album on Imgur), but it doesn't work. I press the red key, then 1, then 0 and pressing the 0 makes the printer make 2 extra beeps after the first beep.
    I couldn't find anything in the manual (Ricoh Aficio SP C222SF Manuals) about this issue, and I'm not sure what else to do.
  • davel
    • Oct 2011
    • 1103
    Re: [Ricoh SF C222SF] SC543 error and trouble accessing maintenance mode
    just press red,then 1 then 0 then 7 then press and hold colour start, should get you into maintenance mode. You probably need a new fuser. If you are not a tech be carefull or you could damage the printer.
    OK just read your profile and see you are not a tech, I advise you call one.
    • bloodorange
      • Apr 2020
      • 3
      Looks like you didn't read the post. I did do what you said and it doesn't do anything. When I press the 0 and colour button in the sequence you describe, there are 2 additional beeps that play which I'm guessing means the printer doesn't recognise that command.
      • davel
        • Oct 2011
        • 1103
        Refer to my last statement, are you pressing one button at a time?
        • bloodorange
          • Apr 2020
          • 3
          Yes. Each time I press a button, a single beep is heard, and this does not pull up the Maintenance Mode screen. If I press the sequence very quickly, the beeps are not heard.
            • 37481
            Let me emphasize what davel has already said, CALL A TRAINED AND QUALIFIED TECHNICIAN!!!!!
            Either that or buy a new machine.
