Ricoh C4503 SC670-01
  • Tech09
    • Apr 2020
    • 148
    My original call was for 681 codes, was getting both 08 and 14, cyan and yellow respectively. I replaced all four TCB's. Then machine displayed the SC670-01 at start up. I have since replaced (not necessarily in order because this machine has fried my brain) the BCU, IOB and Controller board. Somewhere in there I flashed firmware. Throughout this whole ordeal the LED sequence on the BCU has changed repeatedly, it has displayed a steady flashing, three flashes then pause for four seconds and two flashes then pause for four seconds. Sometimes changing different components, unplugging connectors or reseating the EEPROM will make that LED series change, sometimes it doesn't. I've looked through other posts about this problem and have tried all those "fixes" as well, still boots up to a SC670-01. Any new advice would be greatly appreciated.
  • fshead
    • 2378
    Re: Ricoh C4503 SC670-01
    maybe control panel,also bad toner chips can give you weird crap so i pull them and turn on machine and ck if any change
      • 37653
      SC670-01 is a mechanical problem detected at engine startup. One possibility could be a broken waste toner auger.
      • Tech09
        • Apr 2020
        • 148
        I pulled all the toners and booted it up, also booted up with all the doors open and it still comes up with the code.
        • GIUBOSS
          • 1437
          When you replaced the two development units C and Y the code 681 - 08.14 disappeared? Try returning to the original code by putting the original boards back.
          • davel
            • Oct 2011
            • 1109
            Nowhere did he say dev units were changed, TCB's were changed.
            Repeat procedure for replacing TCB's make sure no wires pinched, connectors missed.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Was it a new IOB or a used one from a donor machine?
              I had this on a recent machine after swapping the IOB with one from a donor.
              Went to a 3rd machine and used THAT IOB and it fixed my SC670-01.
              • sandmanmac
                • 3990
                Interesting thread here that may offer a simple solution:
                Sc670 - mpc6003 / mpc5503 / mpc4503
                • GIUBOSS
                  • 1437
                  you're right, I thought so as described in the service manual.
                  • Tech09
                    • Apr 2020
                    • 148
                    It was a new one. Everything I have replaced so far has been new.
                    • Tech09
                      • Apr 2020
                      • 148
                      Yeah, I saw that before I posted my thread, tried it and it didn't help.
                      • Tech09
                        • Apr 2020
                        • 148
                        Don't have the originals anymore and it boots up with the 670-01, I don't know if it gets far enough in the boot process to where it would register the 08 or 14.
                        • hernandeze007
                          I fixed once SC670 on a MP c5503 by replacing the controller and the HDD at the same time. But really solved the problem was the HDD
                          • TechTech
                            • May 2025
                            • 1
                            If you swapped the controller make sure the ROM chip is in properly!
                            • MIGUELMARCHENA
                              • Feb 2018
                              • 197
                              Well, look what happened to me.
                              The message "I installed the yellow unit correctly" appeared, but it was fine.
                              I thought about the chip reader, but it was fine. I changed the cartridge, etc.
                              SC 670
                              What had burned out was the yellow TD-L.
                              I caught it quickly because it had already caused me pain on another one, but it was the black TD-L.
                              You'll check... who knows?
