Ricoh MP C4500 SC202
  • sandmanmac
    • 3977
    #16
    Re: Ricoh MP C4500 SC202
    Originally posted by stuuk
    this was picked out as an alternative, but when i tried it it didn't fit, the connector was different, the ones in the manual ended 0318 and 0286
    eBAY:
    Ricoh AX06-0286 Polygon Mirror Motor AX060286 | eBay
      • 37181
      #17
      Those are the older and oldest motors that had a separate board. To replace with the new motor AX060396 Polygon Mirror Motor DC24V and D0295237 Harness: Image Forming Section: Motor must be replaced together. After that you can just replace the motor.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        #18
        Originally posted by sandmanmac
        Spot on that will work
        Regards Mark
        • farhad
          • Apr 2020
          • 40
          #19
          hi
          1 check you machine doors swich
          2check you machine poligon motor to easily rotating
          check you machine ld unit mirors to clean
          have good time
            • 37181
            #20
            You cannot rotate a polygon mirror motor fast enough by hand.
              Correct.
              And you wouldn't notice any wobble ect.
              You shouldn't touch the reflective surface either.
              He is posting some stupid comments. I doubt his skills.
