Ricoh MP C4500 SC202
  • stuuk
    • May 2017
    • 13
    [Error Code] Ricoh MP C4500 SC202
    would like an opinion on this, had sc202, the screen is fine, so i think no issue with BICU, checked earthing contacts to duplex unit, all's well, PSU seems fine also, after removing and cleaning polygon motor, it came to ready and i copied about 10 pages and then the error occurred again, convinced its the motor, but i have a dilemma, the primary and secondary motor part numbers have been discontinued, which leaves me the option of ordering a very expensive laser unit, am i overlooking something of is it definitely the motor ?
  • Hadster
    • Aug 2011
    • 264
    Re: Ricoh MP C4500 SC202
    95% of the time I have had to replace BICU & polygon mirror motor at the same time. 95% of the time!
    Sent from my LG-US998 using Tapatalk
    • anothertech
      • 1771
      Did you try to order AX060396 Polygon Mirror Motor?
        • 37641
        Have you even tried an internet search for Ricoh AX060396? Precision Roller has them in stock for $214.95.
          • 37641
          I have a feeling that he has the original parts catalog from before TSB 037R where the motor and the driver board were separate parts. Motor part number was AX060318.
          • fshead
            • 2378
            I have not mucked around on that model but if i was you i would see if you can part out a mp3300 or mpc3500 laser unit and see if motor can connect and fit.
            Many years ago i use to take apart panafax FAX laser motors and clean the pivot point where the laser spins on its axis..
            I would not 200 to 300 on a maybe that will fix it, if it was me..
            • fshead
              • 2378
              with a little google i found
              For Use In:
              Ricoh Aficio MP C2000
              Ricoh Aficio MP C2500
              Ricoh Aficio MP C2500SPF
              Ricoh Aficio MP C3000
              Ricoh Aficio MP C3000SPF
              Ricoh Aficio MP C4000
              Ricoh Aficio MP C4501
              Ricoh Aficio MP C5000
              Ricoh Aficio MP C550
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Wow..for a second there I thought this was a 10 year old thread.
                A quick look at Google would have lead you back here anyway....it's an old machine with a common fault.
                As Hadster said...make sure you swap out the BICU and the polygon mirror motor at the same time.
                • anothertech
                  • 1771
                  I'd try the motor first, then the BICU if need be. If the BICU is fried it will not hurt the motor. Some BICU's can be fixed if you can find out what got fried. We used to call Hytec, sometimes they can tell you what component to check and replace.
                    • 37641
                    That was only if you had a blank display but could still see the SC 202 by shining a flashlight at an angle across the screen or by going into WIM. If the display is not blank, the BICU does not need to be replaced. If the display is blank and you do not replace both, it could blow the one you replaced.
                    • Polo-022
                      • Sep 2007
                      • 491
                      Replace the polygon mirror motor as soon as possible,
                      what you see now it's the first stage.
                      It will fry BICU and you will see the black screen.
                      • UNICORNico
                        • May 2018
                        • 308
                        As other colleagues have commented, I also recommend the same thing, do not miss too much time and disconnect the device completely from the electric power supply. To avoid on, by the user accidentally, they may aggravate this problem.
                        Replace the Polygonal Motor, before the BICU is damaged, but if the screen darkens (even a little), you must replace both parts simultaneously or the new part you place will be damaged.
                        We had this situation a few years ago with the "MP C5000-C4000" series, which we still had in maintenance.
                        "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          It will be the motor cleaning no good just replace if you order AX06 0286 Polygon Mirror Motor if there's been any part number change the supplier should know
                          Regards Mark
                          • stuuk
                            • May 2017
                            • 13
                            this was picked out as an alternative, so was ordered, but when i tried it it didn't fit, the connector was different, the ones in the manual ended 0318 and 0286.
                            I believe the issue with BICU takes out the back light of the LCD screen, I have had this on several occasions in the past, I don't have that here, the screen is fine and as i mentioned, it did come to ready and briefly work, before sc202 reoccurred
                            thanks for all your help, i think i can get my hands on second hand laser unit
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              this was picked out as an alternative, but when i tried it it didn't fit, the connector was different, the ones in the manual ended 0318 and 0286
                              Tell the supplier they got it wrong the last parts manual is dated 2006 order the one ending 0286.
                              Also is it a ricoh dealer or ricoh directly that gave you the alternative. I check online tomorrow
                              Regards Mark
