Remote Panel Operation on a mobile device
  • Qball
    • Jun 2013
    • 127
    Is there a mobile device based method to access the Remote Panel Operation on a so equipped Ricoh MFP? Does Ricoh Smart Device Connector accommodate this?
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Remote Panel Operation on a mobile device
    Yes it does get from app or play store machine and phone/tablet needs to be on the some network is phone using same WiFi router. You also need to add the machine in the ricoh smart connector
    Regards Mark
      • 37479
      RICOH Smart Device Connector should also be able to connect using NFC, blue tooth or the low power WiFi built into the SOP, provide those have been properly configured. You have to have the mobile device in very near proximity to the SOP.
      If you are at the machine and it has the browser setup on the SOP, you can access WIM through the browser function.
      • anothertech
        • 1768
        Once he gets connected, what would this be used for?
          • 37479
          Depends on which Ricoh App. Print Scan access the browser
