ricoh sp c250
  • mrgene
    • 53
    [Error Code] ricoh sp c250
    Hate to ask but could someone please help me out on this small color laser printer. it spits out some blue in spots but most of the blue is not there, I tried a new cyan unit but that did not help , the machine says density senser needs cleaned, I have no ideal how to get in to the service mode or even where this sensor would be.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: ricoh sp c250
    If sounds like just needs new cyan toner it's one assy including pcdu.
    Regards Mark
      • 37556
      Re: ricoh sp c250
      Ricoh stopped putting how to access SP mode in their service manuals years ago.
      From an older manual here is the way used on most Ricoh printer only models:
      Method 1:
      If you switch the machine off, any jobs stored on the hard disk using the sample print and protected print features will be deleted.
      Method 2:
      The machine automatically goes off line when you enter the service mode.
      Key names may have cjhanged
      • davel
        • Oct 2011
        • 1107
        Re: ricoh sp c250
        Read your user manual for how to clean Id sensor. Call a tech that knows this printer.
        • GIUBOSS
          • 1437
          Re: ricoh sp c250
          if dirty with the new cyan toner it could be the transfer or it is the residue of the old toner, however, clean everything by removing all the groups. The sensor is at the bottom you have to remove the cyan and you should notice a lever with a blue plate to indicate that you can move it to the left and a spring reposition it to the right, this movement makes the sensor clean.
