C3351 Error Code C-2153
  • ErthBoi
    • Oct 2019
    • 7
    [Error Code] C3351 Error Code C-2153
    Hi guys,
    Has anyone come across Error code C2153 from a BIZHUB C3351? If so please foward the remedy and necessary steps taken to solve this problem.
    Regards
  • copyman
    Owner / Technician
    • Sep 2005
    • 4624
    Re: C3351 Error Code C-2153
    Originally posted by ErthBoi
    Hi guys,
    Regards
    I've never had that code but the code is related to the transfer belt.
    Remove the transfer belt and inspect. Make sure not torn or binding.
      Hi guys,
      Regards
      please next time place put your post in the proper forum https://www.copytechnet.com/forums/konica-minolta/
      • tsbservice
        Field tech
        • 7975
        It's - Transfer belt spacing fault at K pressure switching.
        Did you follow procedure in manual for troubleshooting?
        First check ITB as copyman pointed, next are SD1, M1 and MFPB itself.
        P.S
        Eventually You will need manual if working on one of these.
        • sencersur
          • May 2022
          • 2
          C 2554 Abnormally high toner density detected Magenta TCR sensor.
          Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
          • sencersur
            • May 2022
            • 2
            i think it would work. tellculvers com survey taco bell breakfast hours
              • 37357
              You are a grave robber obviously know absolutely nothing about Ricoh development units.
              • davel
                • Oct 2011
                • 1094
                Grave robber yes, but thread is not talking about a Ricoh.
                  • 37357
                  When idiots open or reply to posts in the Copier Technical Discussion forum instead of the correct manufacturer forum, you can expect all senior technicians are going to reply.
