SP registration data outprint mpc3002 (f.i.)
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    Is there a way to only print out the SP registration data of trays, by-pass and DF?
    Thanks in advance.
  • sandmanmac
    • 3981
    Re: SP registration data outprint mpc3002 (f.i.)
    Originally posted by Mark Bbb
    Hoi,
    Thanks in advance.
    No. But it would only take you 30 seconds to write it down if it's that important to you
      • 37532
      If you have writer's cramp and can't write it down, you can us SP 5992-002 to output SP Mode Data Text to an SD card and then edit the file.
      • Mark Bbb
        • Jun 2012
        • 1662
        Sometimes the registration done at factory is not 100% correct.
        Or when machine has some years.
        So, re-adjusting needs to be done.
        And i thought, lazy as i am, to print out those re-adjusting settings...
        Thanks for the input.
        • davel
          • Oct 2011
          • 1107
          Print SP non default data.
          • fshead
            • 2376
            take a pic with your phone..
            I use my phone for reference all the time
            • UNICORNico
              • May 2018
              • 308
              Hoi,
              Thanks in advance.
              What data do you mean by drawers, bypass and ADF???
              If you mean the jams/incidents you find it at 5-990-04
              "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
              • copier tech
                • 8172
                Inside the front door there should be the factory SP printout use that for reference.
                • fshead
                  • 2376
                  good luck with that as ..techs here must eat them as i very seldom find them on lease returns
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Jip, sp5990-06
