SOP Programming
  • sandmanmac
    • 3964
    [Misc] SOP Programming
    Hey all,
    Not surprisingly, I'm finding myself with a lot of downtime these days, so as an Indy, I've been spending some of it by taking apart machines to educate myself on some models that I don't have much Technical experience with in order to get more familiar with them, and also playing around with the SOP's for the same reason.
    I've got what hopefully isn't a really silly question, but I just can't seem to figure it out:
    I've attached a picture of the screen, and I'm wondering how to program Apps in the (blank) boxes in the top left corner?
    I came across a machine at one of my wholesalers recently that had them programmed for "Copier, Fax, and Scanner" so they act as sort of quick access options from within any screen, which seems pretty convenient.
    Any advice on how to do that?
    Thanks!
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: SOP Programming
    Originally posted by sandmanmac
    Hey all,
    Thanks!
    [ATTACH=CONFIG]45687[/ATTACH]
    Just hold and drag like a tablet
    Regards Mark
    • sandmanmac
      • 3964
      Re: SOP Programming
      Thanks, but been there, tried that.
      • Notrons
        • Apr 2016
        • 69
        Re: SOP Programming
        You can find all the pre-loaded apps by selecting an icon, that looks like a waffle, somewhere on the right side of the SOP. Then, just drag and drop.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Re: SOP Programming
          Sorry I know where you mean now 3 empty boxes I check
          Regards Mark
          • sandmanmac
            • 3964
            Re: SOP Programming
            Again, it's the blank buttons in the very top left of the screen (see picture) that I'm trying to assign.
            Thanks for the advice, but I'm well aware of how to move the apps and widgets around the screens
            • skinnyb
              • Jul 2008
              • 291
              Re: SOP Programming
              Only time I have ever seen those shortcuts is when a Java app (Streamline NX, Auto store, etc) has been loaded. Evidently those icons are part of the programming of those applications and not a native function...
              Sent from my LM-V405 using Tapatalk
              • mikadonovan
                • May 2008
                • 2931
                Re: SOP Programming
                Look for a little box on the right side of home screen that has 12 dots in it. Select it after the home screen is done loading (it takes a minute). Those are the apps available. Those "classic apps" should be included.You might want to scroll right to the widgets, too.
                NEVER ASSUME ANYTHING
                • sandmanmac
                  • 3964
                  Re: SOP Programming
                  Ahhh....That makes sense. I think I have my answer.
                  Thanks for that!
                  Too bad that's the case. Like I said, It's a pretty convenient way to quickly access a function from any screen
                  • Notrons
                    • Apr 2016
                    • 69
                    Re: SOP Programming
                    Ohhhhh......sorry, your talking about the function buttons on the top left. I believe they can be set up from the screen features settings..screen device settings...function key settings.
                    • sandmanmac
                      • 3964
                      Re: SOP Programming
                      Excellent!
                      I was sure that I had gone through there, but I just had another look and you're exactly right. It worked.
                      Thanks a bunch!
                      • skinnyb
                        • Jul 2008
                        • 291
                        Re: SOP Programming
                        Well I learn something new every day! I always had customers that loved the hard function buttons on the older devices. That totally makes sense....
                        • mikadonovan
                          • May 2008
                          • 2931
                          Re: SOP Programming
                          Oooohhh K, I get it now. The machine I was looking at does not have them. BUT, now I know how to make them appear. Life is good. Sorry Sandy, I was no help. Have a great day.
                          • sandmanmac
                            • 3964
                            Re: SOP Programming
                            We all learn something everyday in this industry it seems, and that was my feeling too.
                            It seemed like a step backwards, and the "Classic" apps are still much preferred over the foolish "Quick Copy" apps, etc., in my experience, so I like that you can program them (or any other function) as sort of "hard keys" on the SOP as wellSOP.jpg
                            • copier tech
                              • 8104
                              Re: SOP Programming
                              Excellent!
                              Thanks a bunch!
                              If you really have time on your hands have a play with the remote panel & customisation apps.
                              You can create your own wallpaper & icons etc.
                              For a laugh I changed the copy app to my face!
