Mp 1350 reduce speed
  • bojans
    • 1313
    Hi,
    I have this MP 1350 at place where customer prints mostly NCR, carbonless paper. Also That paper is low quality. Wish If I could reduce the speed of the machine to 90 cpm. Does anyone knows if there is settings in diag to change?
  • anothertech
    • 1766
    Re: Mp 1350 reduce speed
    Is the machine jamming? Be prepared to replace the registration roller when running NCR on this model. It's kind of a pain to get the registration assy out.
    • bojans
      • 1313
      Yes, NCR just eating reg roller. But, it's too fast to run this low quality NCR on 135.i have another unit mp 9000 and it works just fine.
        • 37453
        Pick-up roller Feed roller AF030071
        Feed roller AF031041
        Separation roller AF032041
        • mikadonovan
          • May 2008
          • 2931
          Setting the driver to thick paper should reduce the speed. LOL. Looks like Slim beat me to the draw.
          NEVER ASSUME ANYTHING
          • bojans
            • 1313
            This setting is only for thick papers. We are having problems with 60gsm paper.
            • mikadonovan
              • May 2008
              • 2931
              I have used "thick" setting a few times to solve imaging issues while using paper that was not in the "thick" category because of it's lighter weight. Have you tried it to see if it would work?
              • mikadonovan
                • May 2008
                • 2931
                Junk in, junk out. I know it is a hard sell to tell the customer their media is insufficient to do what they want to do, but sometimes it's necessary. You may have to try another brand of NCR just to show them, if that is in fact the problem.
                • Mocafer
                  • Mar 2015
                  • 23
                  Hi,
                  You have to rewire the fuser connector as it is on the 90-page machine. This works the other way around too. the machine will start working at 90 pages. that is why melters are not compatible with each other.
                  Make sure to change both, the fuser connector and the connector of the machine.
                    • 37453
                    late to the party and giving bad advice. One of the lamps on the 1350 is different and the the hot roller is different.
                    • Mocafer
                      • Mar 2015
                      • 23
                      Do not be angry, if I propose this solution, I have tried it, and it works on this line of machines and also on the hobby line 1075, mp7500, etc., it is true that it has a different lamp and a more robust roller, precisely to keep the temperature at more speed, in this case he has to run slower so no problem. I have like many slower machines that are cheaper and I modify them so that they run faster, I have hobby 1075 machines that the mechanical counter has already closed again, hahaha. Do not be angry that life is very short.
