mpc2800 5" lines
  • Mark Bbb
    • Jun 2012
    • 1662
    mpc2800 5" lines
    Blurry lines at 5" interval, transversal to paper travel, also visible in color mode.
    5" = PCU?
    Thank you again for your answer.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: mpc2800 5" lines
    Can you post an example?
    Hit it.
    • Mark Bbb
      • Jun 2012
      • 1662
      I wish i could, but sometimes it refuses to upload pdf's.
      "upload of files failed"
      • Mark Bbb
        • Jun 2012
        • 1662
        not even with firefox, it won't upload.
        • fshead
          • 2360
          i would check the paper transport assembly,maybe broken pin in rear where it pivots.
          OR the housing itself.
          Sometimes i see ITB unit get humid from sitting and the cleaning unit does not clean right.
          I would pull all drums,ITB unit and fuser and look for worn parts.
          I just had one i took in trade and had sold and was jamming only on 11by 17 and it turned out to be that
          rear plastic pin on the transport unit...I used a quality crazy glue and drilled thru it and used a this nail with a small
          head to give it support..Now it works..
          • Mark Bbb
            • Jun 2012
            • 1662
            FShead, that is exact what i just did: paper transfer unit swaped, no good.
            Checked ITB, F.U. pcu, seems to be all good.
            5" ????
            • fshead
              • 2360
              5" ????
              I have no idea what the copy looks like..
              I have done a lot on these series and was a real pleasure learning them..
              I would stop a test print pre fuser and see if it on the unfused paper
              • Mark Bbb
                • Jun 2012
                • 1662
                Both pcdu & fu needs to be replaced.
                Had a lot of bad luck in the previous weeks with referbishing Ricoh's.
                Makes corona even harder to cope with.
                • fshead
                  • 2360
                  SO this was a "SELECT SERIES"...
                  THAT IS what ricoh calls their refurbs in us
                  • FrohnB
                    • Jul 2017
                    • 1919
                    Just checked and PCU's are about 5" in diameter. The Fuser belt would be more like 7".
                    So PCU would be what i would suspect.
                    EDIT: Didn't see your post that said you're going to replace those items.
                    Omertà
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      5" = PCU?
                      Really need to see samples
                      Regards Mark
                      • anothertech
                        • 1760
                        Run individual colors one at a time to see if it's one of the drums.
                        • fshead
                          • 2360
                          i agree with you.
                          make sure individual colors is turned on and do partial 2 inch sky shots with paper blocking lead and trail edge.
                          i cant see 4 drums all going bad at once
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Hoi,Thank you for your helping.
                            I'm going to swap units to see what exactly is causing the problem.
                            It's a multitude problem, caused by more than one part and performed after approx. 30 prints...
                            Ghost image, smear image, dots...
                            I' ll keep you informed.
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Sorry, i can not upload the pdf
                              This is poping up:
