SR3210 Finisher not stapling properly Ricoh MPC4500
  • Mobile_Wizard
    • Apr 2020
    • 4
    [Misc] SR3210 Finisher not stapling properly Ricoh MPC4500
    Hi all,
    Looking for some help here - got a SR3210 finisher that is having problems when stapling - staples aren't being punched through the entire paper set - staples are bent incorrectly (crooked staples) - and when it does seem to staple - the staples aren't being bent all the way down completely (if that makes sense) (one side of staple is upright)
    Hard to describe without pictures I know forgive me! I am not able to get to the machine currently - and i only had a 1 hour window to look at the machine previously.
    No error codes on the machine - staple cartridge been replaced - I've removed the staple unit from the machine - no obstructions - no missing springs etc, gears are good - everything looks normal. Cheating the front door and watching the staple unit in operation everything looks normal - although some sheets in the set looked like they didn't make it all the way down to the staple unit.
    This model has a staple unit accessible from the front of the finisher - and removable - i thought easiest to replace the whole unit considering it is removable - but the contractor is sending me parts diagrams for the same model - but it appears to have a turning staple unit - so now I am completely confused
    Has anybody had a similar issue? I've attached a field service manual for the model i require - staple unit on pages 45-47 - (One with the green staple cartridge in it)
    ANY help would be very appreciated, as I've inherited this problem because nobody wants to do the job.
    Kind Regards
    Liam
  • davel
    • Oct 2011
    • 1107
    Re: SR3210 Finisher not stapling properly Ricoh MPC4500
    3210 not made for MPC4500, is for 4504 and some others.
    • copier tech
      • 8181
      I would imagine poster meant IM C4500!
      • Mobile_Wizard
        • Apr 2020
        • 4
        MPC 4504 sorry.
        • TonerMunkeh
          Professional Moron
          • 3865
          Stapler could have died a quiet death, do you have one from another finisher you could try?
          Hit it.
          • skinnyb
            • Jul 2008
            • 291
            I never try to repair those staplers when the Jaws stop stapling properly. . Just get another, they are easy to replace.
            Sent from my LM-V405 using Tapatalk
            • Mobile_Wizard
              • Apr 2020
              • 4
              Would someone be able to verify the part number for the staple unit in question>?
              AJ011030
              Kind Regards
              Liam
              • copier tech
                • 8181
                AJ011030
                Kind Regards
                Liam
                Yes this is the correct P/N for the staple ass'y on the SR3210.
                • Mobile_Wizard
                  • Apr 2020
                  • 4
                  Thank you appreciate it
                  Although that picture was so small i could barely read it ha ha!
                  Thanks for highlighting it though - appreciate the effort you have gone to!
                  Regards
                  Liam
                  • copier tech
                    • 8181
                    Regards
                    Liam
                    The pic I posted was huge but for some reason this site reduces images down so small!
