PROBLEM RICOH MP C5502
  • tullio
    • Feb 2012
    • 268
    [ATTACH=CONFIG]45950[/ATTACH]
    press and copy problem - the oven group is new. Inserted opc black from another machine, same problem.
    The prints are clear.thanksthe prints are clear.
  • 8T2
    • Aug 2015
    • 257
    Re: PROBLEM RICOH MP C5502
    Does the toner rub off? Looks like a fusing pressure problem to me.
    Edit: could also be a transfer/seperation problem if toner does not run off
    Sent from my WAS-LX1 using Tapatalk
    • FrohnB
      • Jul 2017
      • 1919
      If Prints are fine then I would not suspect the fuser (oven).
      If it's just a copy problem then it could be a number of things.
      What have you done so far to try to fix??
      Have you;
      Cleaned the scanner glass?
      Cleaned the optics?
      Clear "Copier Application Memory in SP mode, and then Run ACC?
      SBU good? Could try swapping with another one.
      Copier settings (Density, Text/ Photo, etc). correct?
      Let us know what you did before you replaced fuser (oven), and PCU.
      Omertà
      • copier tech
        • 8172
        You say the fuser (oven) is new what part number was it? as the MP C3002 fuser is not the same.
        • BsK
          • Mar 2015
          • 7
          Are you using Genuine Ricoh toner?
          I've come across a couple of non gen Black toners in specific that cause cold off-setting similar to your example
          • Gary k
            • Jan 2020
            • 10
            I have had a piece of paper follow the transfer belt, It caused the print to smear like this. The paper gets just past the top of the of the belt unit and cannot be seen from the side, the ITB needs to be removed to get the paper out.
            Gary
              • 37532
              The first things I always did on color machine with light copies was to clean the optics and then run Auto Color Calibration in User Tools. More often than not that was all that needed to be done.
                +1 on this. IMHO this should be the 1st thing done to any color machine that has PQ/CQ problems.
                • wilez
                  • Jan 2011
                  • 55
                  Weak exposure lamp or power output to lamp is not enough get full brightness. Clean and inspect optics and check SC's for exposure errors.
                  https://t.me/pump_upp
                  • mikadonovan
                    • May 2008
                    • 2931
                    Clean optics, ID sensors and then run acc for all modes.
                    NEVER ASSUME ANYTHING
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 195
                      I would say that it is a fuserdid you change the complete and new fuser?or just the fixing sleeve?I bought some and they came out perverse generics.make sure it is the original or a good genericThe case can also be given for generic toner of poor quality, from another reference, etc.but I lean towards the fuser.
                      • tullio
                        • Feb 2012
                        • 268
                        is the oven of the ricoh mpc 3502 the same as the ricoh mpc5502?
                        • copier tech
                          • 8172
                          No, I asked you this before!
                          What fuser sleeve/part number did you fit?
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            In fact, i have the same problem and that is called ghost image or offset.
                            the same problem you have here.
                            I have replaced only the sleeve unit, but it didn't help.
                            A mpc3002 (of spc830) fusing unit can be used in a c5502 if you swap the bottom plate and connector.
                            • Zeldaman
                              • Mar 2011
                              • 946
