Ricoh MPC 5503 making loud noise
  • Alex1
    • Oct 2012
    • 285
    Hi all, I went out to a Ricoh MPC 5503 that makes a loud noise when printing or copying. I changed the image transfer belt and transfer roller thinking the noise was coming from them as they were showing heavy wear but not the case. Here is the link to the noise I'm getting any help will be appreciated.
    YouTube
  • tadeusz.dutkiewi
    • 8
    Re: Ricoh MPC 5503 making loud noise
    PCU BLK
    Wysłane z mojego XQ-AT51 przy użyciu Tapatalka
    • Alex1
      • Oct 2012
      • 285
      Originally posted by tadeusz.dutkiewi
      PCU BLK
      Have you had this problem before? What makes you say PCU BLK? Sorry this machine is a fair drive away from me I wanted to make sure.
      • tadeusz.dutkiewi
        • 8
        in. MPC5503, problems with strange sounds are: vertical paper running, iPCU unit (spring tension adjustment.),fisting unit All these problems were described in detail in this forum.
        • Alex1
          • Oct 2012
          • 285
          Is fisting unit meant to be fuser unit?? Also link doesn't go anywhere.
          • tadeusz.dutkiewi
            • 8
            If you can't find: it's about the noise coming from the sleeve unit (felt heating tape - you have to grease it)
            • Alex1
              • Oct 2012
              • 285
              To run the test I will replace the fuser unit with another one and see how it goes.
              • DRichard
                • May 2008
                • 482
                Do not, I repeat DO NOT , Google "fisting unit"!
                "Enjoy every sandwich."
                -- Warren Zevon
                • Alex1
                  • Oct 2012
                  • 285
                  Lol I won't. I don't want to imagine what explanation will come up.
                    Especially at work.
                    • tadeusz.dutkiewi
                      • 8
                      but you have fun, it's my spelling mistake, I write from the phone, it's about the heating unit, I'm sorry everyone
                      • TonerMunkeh
                        Professional Moron
                        • 3865
                        I just spat my coffee out.
                        Hit it.
                          • 37517
                          The only strange noise that I noticed in your video seemed to occur only during paper feed. As soon as the registration roller takes control of the paper, no noise.
                          • FrohnB
                            • Jul 2017
                            • 1919
                            Check all your transport rollers!
                            The little "belt rollers" on the right hand door can have the belts wander to one side and cause a noise.
                            Check the white plastic rollers on right hand door and lube those.
                            If it's just that initial squeaking/ rubbing sound, then I don't think the issue is from any "unit", otherwise it would continue to make that sound during the print cycle. Or does it??? Kind of a short video to determine that from.
                            EDIT: There's also a bulletin about the duplex rollers touching the cover and a bracket that make a squeaking noise. Just apply grease to those shafts.
                            Omertà
                            • FrohnB
                              • Jul 2017
                              • 1919
                              Omertà
