MP 7001 slow print answer
  • mikadonovan
    • May 2008
    • 2931
    First, if the title of your thread ends in the word "print" nobody will be able to respond to the thread. As far as the problem do not use any print driver but the PCL6 (not the universal). WSD and built in windows "Ricoh Class drivers" are junk.
    NEVER ASSUME ANYTHING
  • Zastawa
    • May 2019
    • 25
    Re: MP 7001 slow print answer
    Thank you for both tips.
    • tsbservice
      Field tech
      • 8019
      Thanks mika, definitely annoyingforumbug for both posters and one wanting to reply.
      I use to PM poster or start a thread on behalf of poster but still feel awkwardness.
      • dalewb74
        • Feb 2018
        • 1153
        i haven't had an issue with the ricoh universal print driver. it's usually whenever microsoft tries to install it's driver we start to get issues. usually if i remove MS driver and just use the ricoh seems to work well. just my 2 cents. that being said i haven't used it on the model you are referring to. so.......
          • 37514
          There is no problem with "Universal" print drivers. They are absolutely necessary with some pooled printing. In order for pooled to function properly, every device in the pool should have the same driver.
          • Zastawa
            • May 2019
            • 25
            Thank you all, I will take a closer look at the drivers.
            • tufbnme
              • 493
              I use nothing but the PCL6 Universal. Keep it updated and it works great. Never had an issue.
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                  • 37514
                  But you do not need to use print management software in order to pool print devices. PCL6 Driver for Universal Print PCL 6 driver to offer full functions for Universal Printing. This driver enables users to use various printing devices. The availability of functions will vary by connected printer model.
                  If you do not understand pooled printers here is a tutorial. There is one error in the tutorial. You do not need to be from the same manufacturer and of the same model. They just need to be using the same driver hence the PCL6 Driver for Universal Print. In the case of the PCL6 V4 Driver for Universal Print they do not even need to be from the same manufacturer, they just need to all be using a driver that supports the V4 architecture, which Microsoft introduced as its next-generation driver architecture, and offers universal printing.
                  How To - What Is Printer Pooling? How Can I Configure It? | Tom's Hardware Forum
                  • KenB
                    Geek Extraordinaire
                    • Dec 2007
                    • 3944
                    Anyone remember the “mini driver”?
                    I never really used it, but it did save the day once. I had an account about 10 or 12 years ago that printed tons of pages a day from Word Perfect, and they had mixed orientations and duplex settings within the same job. Ugly, I know.
                    I don’t remember the model but it was a Segment 6 Ricoh, no Fiery.
                    No other driver worked like they wanted it to. Out of desperation I tried the mini PCL5 driver and life was good. It basically let the application do the driving.
                    I gained a new respect for it after that little adventure.
                      • 37514
                      I not sure if it was the PCL Mini driver but many years ago we had a customer who when they remodeled their office pulled an old Gestetner 3220, AFICIO 200, out of their warehouse and wanted to put it in the boss's office for him to use as a printer. There was no XP driver for the 3220. So I downloaded the Mini driver and it worked.
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3944
                        From what my fuzzy old brain remembers, you got both PCL5 and PCL6 drivers when you downloaded the Mini driver package.
                        It was really mis-named. It had pretty much if not all the features that the standard PCL drivers did.
                        • mrwho
                          Major Asshole!
                          • 4299
                          If it happens from all computers, it could also be a network problem - try lowering the machine network speed to 10mbps half-duplex. If it improves the print time (even though you lowered the speed) then you got a cable/connection problem
                          Mascan42
                          Ibid
                          • tsbservice
                            Field tech
                            • 8019
                            Yes may be. Ping the machine -t for a 5 minutes. If there are frequent big delays their network is culprit.
