MPC3004 Airprint
  • GeorgeBest
    • Jul 2009
    • 526
    MPC3004 Airprint
    Is Airprinting on an MPC3004 a standard feature?
    or is it optionel and do I need a postscript module
    Thanks in advance
    Re: MPC3004 Airprint
    Thanks in advance
    quick search brought up this page.
    airprint doesn't appear to be an option
    MP C3004 Color Laser Multifunction Printer | Ricoh USA
    • GeorgeBest
      • Jul 2009
      • 526
      But only with the app "Smart device connector" . . .
      • FrohnB
        • Jul 2017
        • 1919
        It's standard, so to say.
        You need to download the "Ricoh Device Connector" app on your phone (android or apple).
        Make sure that your phone is on the same network as the copier.
        For Apple you have to either scan a QR code from the machine op panel, or you can enter the IP address of the machine into the app and it will search for the copier that way.
        Once the copier is found, you should be able to print from a webpage, photo album, email, etc.
        EDIT: you don't need Postscript.
        Omertà
        • GeorgeBest
          • Jul 2009
          • 526
          So it doesn't have the 'airprint utility' without the app, which the IMC's does ...
          • FrohnB
            • Jul 2017
            • 1919
            Look on the Web Image Monitor under "Configuration", and on the right hand side under "Network", you should see "Airprint". It's active by default.
            Omertà
            • Brianneoe
              • May 2015
              • 322
              About AirPrint - Apple Support
              Yes it does. You will need to create a Device Certificate for it to work.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Thanks in advance
                Yes it is standard but it's a embedded post script not full Adobe ps3 missing fonts etc if you want to use on mac it's best to get ps3
                Regards Mark
                • ridgemill
                  • Sep 2017
                  • 192
                  Does the customer have an always on Windows PC or server?
                  If so, you can install AirPrint for Windows, which uses the shared printer queues on the server. Also, PostScript isn't needed this way.
                  • Codex
                    • May 2008
                    • 705
                    I think this machines works with airprint out of the box... The certificate is enabled by default...
                    Inviato dal mio SM-G935F utilizzando Tapatalk
                    Memento Audere Semper
                    • copier tech
                      • 8220
                      Thanks in advance
                      Yes for about 5 years on Ricoh!
