Ricoh CL 7200/Reset Change Fuser
  • cucuklotz
    • Mar 2007
    • 611
    HI,
    Can you tell me how to reset the Change fuser Message?The fuser unit is still in good shape and $400 is a lot to spend on new fuser when I can rebuild for customer for 1/2 that.
    Thanks, ANDY
  • rthonpm
    • Aug 2007
    • 2847
    SP 7-804-016 will clear the fuser PM counter. You can easily rebuild this fuser (other than the tension on the springs which are way to tight), though generally all you need to replace are the oil roller and its cleaning roller. Also, the copier version (3245c) fuser will work without issues in this model.
    • cucuklotz
      • Mar 2007
      • 611
      RICOH 7200/Fuser reset
      HI,
      THANK YOU
      I know Im being a pain,but Im not even sure of how to go into simulations,could you ,when you have time give me procedure,
      ANDY
