Ricoh MP 2553
  • Khumz
    • Feb 2020
    • 56
    Ricoh MP 2553
    Ricoh MP2553 prints blank copies. This started after client installed new toner.
  • sandmanmac
    • 3947
    Re: Ricoh MP 2553
    There's no logical reason that this would happen simply from replacing a toner bottle in this model.
    ....and it sounds like you haven't even gone to look at it.
    How about doing that and then actually providing some proper information if you can't resolve it!
      • 22808
      Re: Ricoh MP 2553
      did they pull the TAB?
      properly seat the toner?
      any errors recorded?
      have you been to the site?
      you need to provide more info for us to help you.
        • 35061
        Re: Ricoh MP 2553
        The only reason that I know of where just replacing the toner bottle would cause blank copies would be if there was a lot of spewed toner on the toner bottle holder rails and it got dumped down onto the entire length of the shield glass. If that is the case do not remove the shield glass to clean it until you have vacuumed all the toner on, above and around the glass. If toner falls into the laser housing you will have a major problem.
        • Khumz
          • Feb 2020
          • 56
          Re: Ricoh MP 2553
          Yes toner was spewed all over the place, down into tray 1 and 2, all over developer unit. I vacuum cleaned the entire machine, put it together and its shooting blank copies. No error codes showing.
          • Polarbear
            • Feb 2012
            • 1070
            Re: Ricoh MP 2553
            hi
            Make a print and stop it midway. Open the right door and check if there is image on the drum. If not start by checking if the gear that turns the mag roller on the back of the pcu is there. If that is missing there will be no image on the drum.
            Press the GREEN button!!
            • copyaction
              • Oct 2007
              • 976
              Re: Ricoh MP 2553
              Originally posted by Polarbear
              hi
              that would be a good place to start and also
              How many copies on the drum and developer?
              Was it actually out of toner?
              Mixing gears broken?
              • Mark Bbb
                • Jun 2012
                • 1662
                Re: Ricoh MP 2553
                It is not detecting toner when doing the ID check
                => problem with toner supply:
                OR it is blocked somewhere OR drum / developer bias roller is not turning.
                • Khumz
                  • Feb 2020
                  • 56
                  Re: Ricoh MP 2553
                  hi
                  Everything seems intact, gear in position mug roller turning normal but there is no image the drum.
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Re: Ricoh MP 2553
                    drum charge problem
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Re: Ricoh MP 2553
                      Originally posted by Mark Bbb
                      drum charge problem
                      oh no!
                      you would have full black!!!!
                      sorry !!!
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Re: Ricoh MP 2553
                        the supplied toner is blocked somewhere, check all pcdu openings for obstruction
                        • francisco
                          • Nov 2009
                          • 168
                          Re: Ricoh MP 2553
                          gears in developer unit brocken
                          • DRichard
                            • May 2008
                            • 482
                            Re: Ricoh MP 2553
                            Spilled toner blocking laser from exposing the drum? Clean slit glass and make sure you have cleaned any toner piled outside the laser unit AND inside too. I know you said you have cleaned up the spills, but this is the only other thing that I could think of. My apologies if you have already done this too. Good luck.
                            "Enjoy every sandwich."
                            -- Warren Zevon
                              • 22808
                              Re: Ricoh MP 2553
                              +1
