Ricoh MP 2553
  • mikadonovan
    • May 2008
    • 2931
    #16
    Re: Ricoh MP 2553
    Originally posted by Khumz
    I vacuum cleaned the entire machine, put it together and its shooting blank copies.
    Ok, if you put it together, that means you had things disassembled. If it was imaging before you did that, you need to backtrack everything that you did and check for self-made problems like unseated connectors and such. If you pulled and vacuumed the LD unit, it is possible you smoked a pcb with static, or a cable was reinstalled incorrectly.
    NEVER ASSUME ANYTHING
    • mikadonovan
      • May 2008
      • 2931
      #17
      Re: Ricoh MP 2553
      Ricoh MP2553 prints blank copies. This started after client installed new toner.
      I don't have any of this model, but is it possible the cap from the old toner bottle is stuck in the toner supply unit?
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        #18
        Re: Ricoh MP 2553
        Yes toner was spewed all over the place, down into tray 1 and 2, all over developer unit. I vacuum cleaned the entire machine, put it together and its shooting blank copies. No error codes showing.
        Was it toner or developer could of dumped dev
        Regards Mark
