Tearing paper
  • Rezaarsenalyyyy
    • Mar 2020
    • 25
    Tearing paper
    Hi guys,can anyone helps me?
    Sent from my Redmi 8 using Tapatalk
  • Rezaarsenalyyyy
    • Mar 2020
    • 25
    Re: Tearing paper
    Ricoh mp4001b
      • 37375
      Re: Tearing paper
      It looks to me like only the center transport belt is turning when the lead edge of the paper reaches them. If you inspect them the surfaces might be shiny and slick. Cleaning might help but I would recommend replacement. If you are going to try cleaning and you have any of the Scrubs hand wipes that Ricoh used to put in their PM kits, they work quite well to clean and also scuff up to slick surface.
      • GIUBOSS
        • 1389
        Re: Tearing paper
        It seems that the sheet comes from above instead of from the paper drawer ....?! is it a duplex? Or the paper arrives rolled up because it is damp or poor and stops on the belts. Try if it does the same with the other paper cassette and the bypass tray.
          • 37375
          Re: Tearing paper
          If you are referring to the first picture, I think it is just to show the relation to the transport belts.
          • mrwho
            Major Asshole!
            • 4299
            Re: Tearing paper
            +1
            Mascan42
            Ibid
            • Zaxxon
              • 608
              Re: Tearing paper
              Take the belt out, clean and install 180 degree turned.
              Please start you post with brand, model, problem.
              • Polarbear
                • Feb 2012
                • 1070
                Re: Tearing paper
                Quick question.
                Are all the plastic guides in place and not broken?
                That looks like the paper is being fed out the tray, then collides with the feed on the right door and then only is fed further.
                Had that before when guides are dislodged and sitting skew or break and the customer quietly removes them, and then logs a call for what is evident in your photos.
                Press the GREEN button!!
                • MIKON
                  • Jul 2015
                  • 186
                  Re: Tearing paper
                  is that center belt spinning freely like the ones that are causing the fold?
