Ricoh MP C 8002 Clear company login
  • normy945
    • Apr 2018
    • 10
    I am looking at buying a unit from a wholesaler, but it is asking for company login. How do I clear this??
    • 37068
    Re: Ricoh MP C 8002 Clear company login
    Most likely some type of User Authentication which can be turned off in either WIM or User Tools - System Settings - Administrator Tools. If it is Kerberos or some other high security authentication protocol you may also need to turn off IEEE 802.11.
    • sandmanmac
      • 3973
      If you're an end user and not a tech, and I'm pretty sure that's the case based on the limited information of your query.
      Depending on who, what,when, and where this machine was, it could be heavily locked down with passwords, and restrictions.
      I'm finding it more and more common these days, and with all due respect, there is not one single solution. There are a variety of the things that may prevent you from getting it set up on a network, if you're not specifically familiar with the technical aspects of RICOH devices,
      all of which have been discussed in detail in multiple threads
      • davel
        • Oct 2011
        • 1089
        Don't buy it.
        • mrwho
          Major Asshole!
          • 4299
          Factory Mode
          SP5846-46
          (I think...)
          Mascan42
          Ibid
          • copier tech
            • 8121
            "Company login" you need to clarity, as there is no such thing as this.
            Can you post a picture of this message?
            Sounds like they have a software solution installed.
            • Zaxxon
              • 608
              Originally posted by davel
              Don't buy it.
              these boxes are old 6-7 years my advice too.
              Please start you post with brand, model, problem.
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Originally posted by mrwho
                Factory Mode
                SP5846-46
                (I think...)
                +1
                Regards Mark
                • bob marley
                  • Jan 2012
                  • 1339
                  +1
                  Live for yourself and you will live in vain. Live for others, and you will live again
