MPC3502 ADF "GRUNT"
  • fshead
    • 2376
    MPC3502 ADF "GRUNT"
    HI
    I have a mpc3502 making noise as paper begins exit on the adf.
    Change feed belt, sep roller and clean one way clutch wth alcohol.
    Cleaned all rollers and guides and get noise still.
    it seems less when doing it 8 1/2 x 11 R than normal,faster letter..
    ITS almost like a buckle sound..
    Will swap the sep roller one way gear but any ideas?
    thanks
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: MPC3502 ADF "GRUNT"
    Take of rear upper cover. Enter SP mode, ADF output check. Narrow down.
    • fshead
      • 2376
      hi
      i dont feel it s going to happen unless it pases paper..
      I had to be somewhere else and didnt spend the time needed to
      look further and i didnt want to pull everything apart with no time at hand.
      Kinda weird noise comes and goes
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Originally posted by fshead
        HI
        thanks
        You do get a noise from the belt roller {one way bearing} clean shaft lub bearing or replace
        Regards Mark
        • fshead
          • 2376
          no noise at pickup but as paper just begins exit..
          I have a spare ADF UNIT, as i will swap the adf head and sep roller one way gear and if still making sound i will swap feeder
            • 37532
            Common cause for noises it the ADF that starts just after the trail edge of the paper enters is usually the caused by a dirty separation roller, dirty feed belt or both. Not enough friction between the two so the separation roller turn against the belt. Cleaning might help but you will eventually need to replace at least the separation roller.
            • fshead
              • 2376
              THANKS SLIM
              I changed those parts and cleaned all roller,white plate,slit glass etc etc..
              It comes just as the lead edge hit the exit rollers
              • FrohnB
                • Jul 2017
                • 1919
                Is it grunting on every sheet that passes, or is it every now and then?
                Usually weird grunts can be a sign of a bad feed clutch. On this series we have had to replace the main feed clutch (P/N: AX210102), and we've had a couple where we had to replace the exit section torque limiter (P/N: D3664242, I will post a pic of this item).
                Have you Lubed all bushings in that area?
                Any of the Timing belts slipping?
                Any warped guides or a guide that isn't opening fully (solenoid not firing all the way).
                Omertà
                • fshead
                  • 2376
                  upon ist inspection,grunting all the time.
                  I changed feed belt,sep roller,cleaned one way sep roller,all transport rollers and ran again..
                  It was ok but after 4-5 original it started and kept at it.
                  i tried running original 8 1/2 in narrow feed and that was ok but would start to grunt after a bunch of originals..
                  I didnt pop rear cover and try spraying alcohol on main clutch as time was running out..
                  I only have less than 02 series and have a whole machine i can gut for parts..
