Ricoh C5110s Fiery Controller software install
  • Oscar57
    • 79
    Hi,
    I have a Fiery E-22B that stopped working. Tell it to print a built in PS test page or print a file to it from Command Workstation and the print job shows printing but doesn't print. So I am going to reinstall the Fiery system software.
    I have it hooked to a PC. Do I need to use a standard Ethernet cable or a crossover cable and to what Ethernet port the top or bottom port? And should Dip switches both be clicked up in the On position or just Dip switch 1. I haven't installed Fiery software in a long time so I can't remember. - Thanks for your help.
  • skinnyb
    • Jul 2008
    • 291
    Re: Ricoh C5110s Fiery Controller software install
    Originally posted by Oscar57
    Hi,
    Never had any luck with the pc and crossover cable method. I would use the USB thumb drive procedure. Prepare the drive and it works like a charm. I believe Dip switch one is on and 2 is off for that method. It's been a while since I've done it too. Last one I did was a E-22C on a MP C4503 (same fiery hardware and procedure)...
    Sent from my LM-V405 using Tapatalk
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Hi,
      If you have access to TSRC, look in the manual section for the copier. The Fiery manual will be there.
      It explains the procedure quite well.
        • 37533
        To begin with, DO NOT DO A DAMNED THING UNTIL YOU HAVE PROPER DOCUMENTATION IN HAND.
        If you are a Trained and Authorized Ricoh technician, contact your regional support rep and schedule a support visit. He/She can provide you with the necessary documentation and will assist you in getting started. In addition login the the Ricoh Learning Institute and sign up for online Fiery training. The training will be supplied by EFI and paid for by Ricoh. You will have 1 year to complete and should include 1 year of support from EFI.
        If you are not an authorized Ricoh tech, EFI training and support will be out of you pocket and could be a few thousand dollars.
        That said, are you sure that you need to fully reinstall the Fiery system. That is a rather drastic measure and normally only done following a HDD crash on the Fiery server using the system restore DVDs. What trouble shooting steps have you done? Are you sure that the connection between the Fiery server and the C5110s is correct? Connection should be from the bottom jack on the E-22B to the gigabit board on the C5110s using the connection cable supplied with Fiery.
        • copier tech
          • 8174
          Hi,
          Before you reinstall the complete Fiery OS I would first check/install any patches first this maybe all that is required.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            Good point.
            It's been years, but I seem to recall not faring very well with the crossover method, either. It was flaky, at best.
            The thumb drive approach never failed.
            • sniper2g8
              • Jan 2013
              • 117
              Hi,
              can you please send the fiery system software to my via email thank you
              smailamensah@gmail.com
                • 37533
                This thread is almost 3 years old. It was dead and buried until you decided to go grave robbing.
