MP C305 Home button
  • ABS tect
    • Sep 2013
    • 511
    MP C305 Home button
    I have a 305 that when i press the home button it just beeps at me. So i can't get to any of my applications unless i have the side buttons as a shortcut, which it only has three, so i have to choose 3 out of my usual 5. I updated the firmware.
    I set the function priority to home but it still stays on the copier screen.
  • copier tech
    • 8133
    Re: MP C305 Home button
    Sounds like you have user/admin authentication set?
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      System Settings > General Features > Function Priority
      - Specify the mode to be displayed immediately after the operation switch is turned on, or when System Reset mode is turned on.
      Default: [Home]
      Or you could try restoring the [Home] screen defaults.
      • ABS tect
        • Sep 2013
        • 511
        Thanks for the response i will try in the morning and get back to you.
        • ABS tect
          • Sep 2013
          • 511
          Neither of those worked...could it be firmware? Maybe the actual display unit is bad?
          Edit: I set the system reset to 10 seconds...when 10 seconds pass it returns to the home screen (which I set as the function priority). But when I'm on the copier screen or something else and hit the home button...it just beeps at me as if nothing has been programmed for that button
          • FrohnB
            • Jul 2017
            • 1919
            I would start with firmware. I don't see anything in the f/w history for that symptom, and haven't personally run into it with this machine, but it's worth a shot.
            If the button beeps when you push it, then i think we can rule out the board in the op panel.
            If firmware doesn't do the trick, then i would be hunting for a setting somewhere in there that's causing it to do that. Like an "interrupt mode" or something like that.
            Omertà
            • frere
              • Jun 2020
              • 12
              It 's a SP mode which was changed, I've had that once but i can't remember which SPmode, sorry. I'll have a look on monday .
              • frere
                • Jun 2020
                • 12
                it could be the SP 5074
                • skynetto
                  • Sep 2012
                  • 257
                  Right
                  SP5074-091 should be 0
                  • frere
                    • Jun 2020
                    • 12
                    Originally posted by skynetto
                    Right
                    Thank you
