Mpc3001 sc531
  • mrfuser
    • 1617
    Mpc3001 sc531
    Ok got the sc531. Changed both fans by the fuser. It will run a single page no problem, but as soon as we try 3 duplexed pages we get another sc531. Any ideas?
    • 37483
    Re: Mpc3001 sc531
    Wrong fans. The fan you need to replace is Ventilation fan(s) at the left side of the machine. The fusing unit is at the right side of the machine. See Airflow fans under Laser Optics in the Replacement and Adjustments portion of the service manual.
    • sandmanmac
      • 3981
      Re: Mpc3001 sc531
      Originally posted by mrfuser
      Any ideas?
      Here's one!
      How about stating that problem in your first thread from 2 hours previous to this one:
      Mp c3001 exhaust fan part
      .....And then, returning to that same thread to update us about your failure, and ask for more help, rather than starting a brand new one!
        • 37483
        Re: Mpc3001 sc531
        Originally posted by sandmanmac
        Here's one!
        You actually expect that much out of mrfuser?
        • sandmanmac
          • 3981
          Re: Mpc3001 sc531
          Foolish me. I can't set the bar low enough!
          And even though he's ignored, I can't help myself from sneaking a peek
          • mrfuser
            • 1617
            Re: Mpc3001 sc531
            I’m sorry to have offended you gentlemen that was not my intention. I was figuring because I had two different questions that I should open to different threads but if the consensus is not to do that then in the future I will not
            I certainly hope that no one‘s feathers were to ruffled
            so the two fans on the left side of the machine by the laser assembly are the problems eh?
              • 37483
              Re: Mpc3001 sc531
              That s what SC 351 indicates.
              • mrfuser
                • 1617
                Re: Mpc3001 sc531
                sc351 or 531? Wi was referring to 531
                  • 37483
                  Re: Mpc3001 sc531
                  My bad 531. Other fan SC would be
                  530 - fusing fan
                  532 - IH Coil fan
                  533 - IH inverter fan
                  534 - Second duct fan
                  535 - Paper exit fan
                  536 - Third duct fan
                  • mrfuser
                    • 1617
                    Re: Mpc3001 sc531
                    Thank you very kindly!
                    • mrfuser
                      • 1617
                      • mrfuser
                        • 1617
                        Re: Mpc3001 sc531
                        I replace the two fans on the left side the front fan comes on no problem but the real one will not come on and I tested the rear one on the front and it comes on just fine
                        any other ideas on this gentleman?
                        • mrwho
                          Major Asshole!
                          • 4299
                          Re: Mpc3001 sc531
                          531
                          - Defective ventilation fan motor-front or rear
                          - Defective IOB
                          So, if you ruled out the fans, and checked the connections, the IOB is your next suspect - D0895123 PCB:IOB
                          Mascan42
                          Ibid
                          • fshead
                            • 2376
                            Re: Mpc3001 sc531
                            i just gutted a mpc3501 since i didnt feel like rebuilding the transfer belt and fuser unit......
                            great box but i like the mpc3503 series better
                            • mrfuser
                              • 1617
                              Re: Mpc3001 sc531
                              Ok ordered and replaced iob and that fixed it. Thanks all
