Ricoh c751 error sc 685
  • stophe_87
    • Jul 2020
    • 4
    Hello,
    i need your help please.
    after a general power outage.
    my ricoh c751 doesn't want to start.
    on the screen I have the error sc 685.
    Thank you
  • mrwho
    Major Asshole!
    • 4299
    Mascan42
    Ibid
    • stophe_87
      • Jul 2020
      • 4
      Re: Ricoh c751 error sc 685
      thank you for your reply.
      i have two ricoh c751,
      I completely changed the two board ( PSU 2 and relay board ).
      but the problem is still available
      • mrwho
        Major Asshole!
        • 4299
        It's possible that the other PSU is also blown - hell, with a power outage, it's possible that any other electrical component is out of order.
        I'd start by double-checking all the PSU2 and relay board connections, and then I'd try to replace the PSU1 also.
        Failing that, it's uphill from there - from the Goose Guide, on another not-so-dissimilar model, they replaced both PSUs plus the IOB.
        Good luck!
        Mascan42
        Ibid
          • 37489
          You may need to get out your test meter and start checking voltages. Once you find what voltage is missing check the point to point to see where that voltage goes to. I had a paper feed motor with an internal short to ground take down the 24V supply on a Pro 1357EX once.
          • stophe_87
            • Jul 2020
            • 4
            Thank you for your answers 🙏🙏
            the second machine works well.
            what's weird is i changed the PSU 2 + IOB + BCU but nothing.
            on the other hand I did not check PSU 1. I will do it tomorrow and I will give you a return.
            Thank you
            • anothertech
              • 1769
              Once you get it fixed, get surge suppressors on those machines.
              • stophe_87
                • Jul 2020
                • 4
                it's really weird.
                even change the PSU 1.the problem still remains.😔
                ( the screen stays black and I have to put a lamp to see the error - sc 685- ).🤔🤔
                • mrwho
                  Major Asshole!
                  • 4299
                  If the screen backlit is off and you can still see the screen error, then there's something else afoot - in older models we'd talk about the bicu and the laser motor (although it would be a different code, if memory serves me right).
                  You would think that's an important detail to tell us...
                  Mascan42
                  Ibid
                  • mrwho
                    Major Asshole!
                    • 4299
                    I never had that problem on that model before (I really don't have any of those machines under my umbrella, tbh), so I did a little research.
                    And couldn't find anything besides what was already said - meaning that, unless someone else can share their experiences, you'll need to start swapping boards one by one until you find the culprit.
                    Mascan42
                    Ibid
                      • 37489
                      You have a short somewhere. Now get out your multi-meter and point to point diagram and start trying to trace it. You might start with the power leads going to the display.
