Has anyone come up with an effective method for cleaning transfer rollers on the RICOH 1027/2027/3025 models? I find that many of these rollers prematurely fail causing thin white banding - I have tried to gently clean the foam composite material that the roller is made of with a soft dry shop rag but this does little to even out the quality of the print. Any suggestions other than replacing the roller would be appreciated - thank you.
Caveman
Caveman
