Black toner keeps on adding
  • tomson25
    • 104
    [Electrical] Black toner keeps on adding
    MPC2003 machine black toner is keeps on adding ,I removed black PCDU from machine and found that toner inlet is full of toner ,what could be the problem?
  • mrwho
    Major Asshole!
    • 4299
    Re: Black toner keeps on adding
    Check the black development gears - they're probably not rotating properly, and so the machine keeps trying to add toner.
    Mascan42
    Ibid
    • 8T2
      • Aug 2015
      • 257
      This. Had many dev units fail on these. Dev unit seized up and your toner supply auger in the hopper is tangled and or snapped off now too.
      Sent from my WAS-LX1 using Tapatalk
      • CopyBats
        • Aug 2011
        • 147
        The coils in the developer unit are very fragile and can easily break when faced little resistance. This can happen within normal operation of machine. Unlike the MP c3003+ models it's not driven by a motor so toner is not always mixed properly which can result in hardened toner causing it to break.
        Refer to this thread as well
        RICOH MPC2003 Black toner empty signal.
        If it works, don't touch it.
          does it print/copy?
          what are you printing heavy fill?
          you really have to give us a lil more info!
          life on pcdu?
          is it dumping inside the machine?
          what does the dev roller look like? nice brush or depleted ?
          • tomson25
            • 104
            machine showing add toner but 10% toner still there ,no print /copy
            PCDU life is 1.2k
            not dumping toner inside the machine
            I have not checked the dev. cylinder
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              +1 for this
              Usual fix is to fit a new Dev assy and toner supply unit.
                Originally posted by Oze
                +1 for this
                +2
                • Codex
                  • May 2008
                  • 704
                  +3
                  Check toner hopper for hardened toner inside... Can cause this problem
                  Inviato dal mio SM-G935F utilizzando Tapatalk
                  Memento Audere Semper
                  • copier tech
                    • 8174
                    Once the dev unit fails toner backs up & breaks the toner hopper.
                    I always replace a dev unit with a new hopper as a set.
                    • 8T2
                      • Aug 2015
                      • 257
                      You work for a nice company we're forced to glue the auger back on.
                      • copier tech
                        • 8174
                        They cost peanuts & so small can keep in the van stock.
                        However I have heard many engineers glue or even melt & mould it back into one piece!
                        • skynetto
                          • Sep 2012
                          • 257
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            +1 for this
                            +4 very common
                            Regards Mark
                            • copier tech
                              • 8174
                              All you need is this small part.
