Mpc5504 scanner
  • tavorh
    • Sep 2016
    • 25
    Mpc5504 scanner
    Hi!
    I bought mpc5504 last week. I notice that in the lower corner scanner up about 50mm, until the machines goes into sleep mode.
    Thanks in advance.
    • 37628
    Re: Mpc5504 scanner
    Most likely what you are observing is the lamp unit being positioned for the document feeder and it moves back to the home position when the machine enters sleep mode.
    • copier tech
      • 8221
      Re: Mpc5504 scanner
      Originally posted by tavorh
      Hi!
      Thanks in advance.
      I have not noticed this before & because the machine can only turn on all the LED lamps not just a few as in your photo this is not normal.
      Does the machine print/copy/scan ok without any issue no SC codes?
        • 37628
        Re: Mpc5504 scanner
        Have they brought back the old practice of only having the white reference patch only at the front edge of the carriage?
        • tavorh
          • Sep 2016
          • 25
          Re: Mpc5504 scanner
          Yes,everything looks ok, when copying,scanning and also without SC code. The machine has also the latest firmware.
          • copier tech
            • 8221
            Re: Mpc5504 scanner
            Next time I go to a 5504 I will check if this is normal but I don't think it is I work of these most days don't remember seeing just a small area of the scan lamp illuminating!
            • mrwho
              Major Asshole!
              • 4299
              Re: Mpc5504 scanner
              I got curious and went to check the service manual - It looks like some sort of original size detection!
              Gotta check it when I'm near one of those!
              Mascan42
              Ibid
              • copier tech
                • 8221
                Re: Mpc5504 scanner
                [ATTACH=CONFIG]46198[/ATTACH]
                Thanks!
                I've only ever seen the complete CCD light for size or original detection, not just 1 small section.
                • mrwho
                  Major Asshole!
                  • 4299
                  Re: Mpc5504 scanner
                  Thanks!
                  I'm not saying it surely is - just making a guess here...
                  Mascan42
                  Ibid
                  • copier tech
                    • 8221
                    Re: Mpc5504 scanner
                    I just can see how the machine can control individual portions of the CCD.
                    • mrwho
                      Major Asshole!
                      • 4299
                      Re: Mpc5504 scanner
                      I'm assuming you mean "can't".
                      Same principle as a ptl light.
                      Mascan42
                      Ibid
                      • Harold D. Keels
                        • Apr 2020
                        • 14
                        Re: Mpc5504 scanner
                        I don't have better experience of using that one you are talking. But I have use Canon and Brother scanner in the past. Both of them served me well.
                        • copier tech
                          • 8221
                          Re: Mpc5504 scanner
                          • mrwho
                            Major Asshole!
                            • 4299
                            Re: Mpc5504 scanner
                            I thought you meant you couldn't understand how the machine could partially activate the led head. My apologies.
                            Mascan42
                            Ibid
