Ricoh mp2501
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    #16
    Re: Ricoh mp2501
    Are the pages gritty to the touch?
    Maybe try another toner supply unit...might not be adding toner correctly.
    • Mark Bbb
      • Jun 2012
      • 1662
      #17
      Re: Ricoh mp2501
      Was the first printout (or copy) after your PM good are - right away - too light?
      Were the printouts also light before your pm?
      • Mark Bbb
        • Jun 2012
        • 1662
        #18
        Re: Ricoh mp2501
        sorry, now in better English:
        Was the first printout (or copy) after your PM good? Or - right away - too light?
        Were the printouts also too light before your pm?[
        • 8T2
          • Aug 2015
          • 257
          #19
          Re: Ricoh mp2501
          Originally posted by Jama
          Yap, original parts replaced, thanks
          I would try adjusting the Dev Bias as a test. Factory is -550 drop it down to -900 to see if it prints darker. If the prints are darker but the copies are still light next I would adjust scanner gamma. All workarounds we had to come up with working for a company that insisted on using Katun drums and type28 developer on these. But be warned the drum cavity will get dirty real quick and toner will build up around mag roller if you have to adjust the Dev bias that low. Parts also won't reach yield
          Sent from my WAS-LX1 using Tapatalk
          • mikadonovan
            • May 2008
            • 2931
            #20
            Re: Ricoh mp2501
            Clean the machine's air/ozone filters, and the ID sensors. Do a forced toner supply till the image looks like you want it, then reset developer again. If the forced toner supply does not increase the image density, then your problem may be a toner supply, or drum ground issue.
            NEVER ASSUME ANYTHING
            • Jama
              • Jul 2020
              • 49
              #21
              Re: Ricoh mp2501
              All too light
              • granata
                • Jan 2012
                • 32
                #22
                Re: Ricoh mp2501
                hi,check A267-3440
                • Jama
                  • Jul 2020
                  • 49
                  #23
                  Re: Ricoh mp2501
                  Originally posted by granata
                  [ATTACH=CONFIG]46219[/ATTACH]
                  hi,check A267-3440
                  ok,
                  • Jama
                    • Jul 2020
                    • 49
                    #24
                    Re: Ricoh mp2501
                    A267-3440 this could be totally plain
                    • Jama
                      • Jul 2020
                      • 49
                      #25
                      Re: Ricoh mp2501
                      What about the toner?
                      OEM Genuine?
                      My bad just noticed oem
                      yes, original
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        #26
                        Re: Ricoh mp2501
                        Did you replace parts and setup according to SM
                        Regardless of toner bottle the first 20 or so prints should be ok as fresh developer.
                        Is the dev unit turning
                        Regards Mark
                        • StephenB
                          • Aug 2015
                          • 243
                          #27
                          Re: Ricoh mp2501
                          You did not say...were the prints ok before you did this work ?
                          And I'm going to throw this out there...did you put the developer drive gear back on the rear side of the PCU ? And check that the drive (spring loaded) on the copier side is moving in and out freely.
                            • 37490
                            #28
                            Re: Ricoh mp2501
                            I have had the damned coupling fall off while sliding the PCDU back into the machine.
