Ricoh mp2501
  • Jama
    • Jul 2020
    • 49
    [Misc] Ricoh mp2501
    Hy, have ricoh mp2501, changed pm parts including Drum, developer, transfer roller, all original parts but still produces very faint copies as before, kindly any leads to this?
    Re: Ricoh mp2501
    during PM did you clean the inside of the machine along with laser glass?
    did you init/reset the parts life?
    what exactly did you do besides replace parts?
    third party crap toner being used?
    Phil B. " The Dentist "
    so many questions .. sooo little info.
    • Jama
      • Jul 2020
      • 49
      Re: Ricoh mp2501
      Yes done everything, including, cleaning laser glass, developer initialization, also original toner in use .... sc392 was displayed at initialization, toner hoper was and toner was outside during initializing
        Re: Ricoh mp2501
        What about the toner?
        OEM Genuine?
        My bad just noticed oem
          • 37532
          Re: Ricoh mp2501
          Light copies and SC392 point to a bad or dirty ID sensor. You may also need to clean the optics including all mirrors.
          • Codex
            • May 2008
            • 704
            Re: Ricoh mp2501
            Had same problem a year ago... Turned out to be the laser unit, had to clean polygon motor and glasses inside, caused by toner dust from the bottle. If it was dirty inside the toner hopper... Probably there is toner dust inside the laser unit.
            Inviato dal mio SM-G935F utilizzando Tapatalk
            Memento Audere Semper
            • GIUBOSS
              • 1436
              Re: Ricoh mp2501
              make sure that both the drum and the development group rotate correctly, block the machine while the sheet scrolls on the drum and check if the image is clearly visible on the surface of the drum. Also if you have a problem in the toner hopper you will have clear copies.
              • 8T2
                • Aug 2015
                • 257
                Re: Ricoh mp2501
                Original Ricoh OPC? Sounds exactly like the problems I ran into when I had to use generic lime green drums for the AF1018. You can turn up the Dev bias but this causes other problems down the line
                Sent from my WAS-LX1 using Tapatalk
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Re: Ricoh mp2501
                  I thought there is an error code when you don't install the toner hopper
                  • GIUBOSS
                    • 1436
                    Re: Ricoh mp2501
                    if I'm not mistaken the code appears only on the A4 like the mp161 etc.
                      • 37532
                      Re: Ricoh mp2501
                      On some entry level models the laser is disabled when there is not toner bottle installed.
                      • Jama
                        • Jul 2020
                        • 49
                        Re: Ricoh mp2501
                        Thanks, will check on same
                        • Jama
                          • Jul 2020
                          • 49
                          Re: Ricoh mp2501
                          Thanks, checked this ...
                          • Jama
                            • Jul 2020
                            • 49
                            Re: Ricoh mp2501
                            Yap, original parts replaced, thanks
                            • Jama
                              • Jul 2020
                              • 49
                              Re: Ricoh mp2501
                              As explained above, did everything, including cleaning optics and laser unit, maybe not sure of toner, toner from client purchase but seams original too, Thanks
