Prrinting Envelops Ricoh 2045
  • squeaker
    • Sep 2025
    Can't get the toner to adhere to the #10 envelope when printing. All other prints and copies look great. What gives?
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    It sounds like it's not fusing correctly, which is usually paper too thick and the machine does not know that the paper is thicker than normal.
    Tell the machine that you're running the envelopes, and tell the machine to run it in thick paper mode. Once the envelope is in the bypass tray, press the # button, which should bring up the special paper menu.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      You might try another brand on envelopes if changing the settings doesn't help. I had a customer with some that just wouldn't fuse.
      • Jimbo1
        • Mar 2008
        • 845
        If they are linen it will likely be a problem.
        "Some days you get the bear, some days the bear gets you."
        Cdr. William Riker
        • lvsb
          • Aug 2008
          • 70
          The 2035/2045 series don't support envelopes.
