Machine cannot power ON
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Electrical] Machine cannot power ON
    Hi friends, My problem is MP4000 machine i turn ON main power switch just one blink comes up on the control panel green light after that automatically machine OFF.I try with another power supply board also but same problem. So what is the problem and how to solve this problem friends please teach me.
    Thank you
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: Machine cannot power ON
    Thank you
    Is the model correct?
    It's not an MPC4000 by any chance is it?
      • 37628
      Try turning the Main Power switch off for 2 or 3 minutes. Main Power switch is located on the left front of the copier. In the front door for the MP 5000 and just below the door for the C5000.
      • Pulsara
        Technical Manager
        • Aug 2015
        • 27
        Check whether power code on the backside properly fit. I had same thing with my customer.
        • kanagavel
          Service Engineer
          • Feb 2020
          • 78
          Hi sir its MP4000 now i solve that problem but machine still showing please wait
          • 8T2
            • Aug 2015
            • 257
            Try disconnecting the HDD and Fax
            Sent from my WAS-LX1 using Tapatalk
            • dalewb74
              • Feb 2018
              • 1167
              you have already tried using a new power cord and different wall outlet?
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                +1
                Regards Mark
                • kanagavel
                  Service Engineer
                  • Feb 2020
                  • 78
                  Sorry for the late response friend, my problem solved already thank for everyone
                    congrats on getting it fixed
                    can you tell us WHAT the fix was?
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Well done thanks for feed back
                      Regards Mark
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        +1
                        Regards Mark
                        • mrwho
                          Major Asshole!
                          • 4299
                          Would be nice to know what the fix was, it could help someone else.
                          Mascan42
                          Ibid
                          • kanagavel
                            Service Engineer
                            • Feb 2020
                            • 78
                            Sorry for the late reply sir.
                            Actually the problem is MP4000 machine can't power ON, when i try power ON its just one blink comes up on the control panel green light after the automatically iys off, then i try with another power supply board but still same problem happend then open back side cover i saw there is one board on the backside of the scanner section its name called SBU board all the connections are cut by someone may be rat or something so i replaced all the Connectors then its working fine. Thank you.
                              yup mice can cause MAJOR havoc in a copier.. have seem image probs due to a dead mice in the scanner section.. they chew thru wires in NAY heat generating areas.
                              Congrats on tracking down the CAUSE of the issue. (needs a mutimeter0
                              If you are a indy tech I would Charge .. make notes in that user's file and Flag them about suggestions:
                              1) If rodent problem is FIXED , future service calls with incur further charges if proven to be rodent damages.
                              a (C)over (Y)our (A) charge .. make it stiff IF they don't comply.
                              2) text the out put of the LVPS with Manual..
                              3) test the harnesses for continuity.. could be a cut/pinched wire in the harness with manual
                              get back with us please
