Ricoh MP C307 cant print or scan to memory device
  • COPIERMAN
    • Jun 2009
    • 559
    I have a use copier we try to use the usb slot and sd card slot to print and scan to memory device on op panel. the sd card slot work fine but the usb slot it see the flash drive but when press on icon it says cannot access the memory storage device. I have look in user tools and service mode and have not found what is causing problem. I was showing a MPC4502 and had samething happen on it. I try mp301 and flash drive works fine with it can print and scan. thanks for any help on this problem
  • sandmanmac
    • 3990
    Re: Ricoh MP C307 cant print or scan to memory device
    It's most likely just not activated. The SD slot and USB slot can be enabled/ disabled separately.
    User tools/ Screen features/ screen device settings/ screen usb memory slot (set to "active")
    • COPIERMAN
      • Jun 2009
      • 559
      I have already check it are both activated. if you have it deactivated and put in flash drive will come up and let you know. I can put flash drive in and will see it and icon comes up on display. but when you press icon that when message come up.
      • 8T2
        • Aug 2015
        • 257
        If you try a different thumb drive? Have had some USB sticks not work but not sure why, possibly formatted in NTFS but never bothered to check
        Sent from my WAS-LX1 using Tapatalk
        • COPIERMAN
          • Jun 2009
          • 559
          I formatted flash drive and check in on a mp301 and works fine.
          • sandmanmac
            • 3990
            Why not include the things that you've already tried in your initial post so we don't waste our time guessing!!
            I'm starting to remember why you were on my ignore list. I'll go back to doing that
            • mikadonovan
              • May 2008
              • 2931
              I originally had trouble getting this to work, too. This procedure must be followed: From scanning screen, select the store file tab at the top. Select store to memory device, then select OK. NOW insert the usb drive, wait for ready, then set your original and hit start.In addition, I have had a couple of flash drives not work at all, and both were PNC.
              NEVER ASSUME ANYTHING
              • COPIERMAN
                • Jun 2009
                • 559
                Hey sandmammac I an not here to waste time thought I was clear on problem. that it see flash drive comes up with memory icon and press on it and message comes up. what you had suggested it would have never made it that far.
                • COPIERMAN
                  • Jun 2009
                  • 559
                  After some other suggestion i try getting a different flash drive mfg was scandisk it works must be something about that flash drive. thanks for everyone help. i did a little more check on flash drives. I had some different ones on hand that were different brands some work and some didn't work.
                  • UNICORNico
                    • May 2018
                    • 308
                    In the installation guides and, commissioning, they usually warn that some "pendrive" or "USB sticks" may not be supported.
                    I understand therefore that RICOH knows that its "controller" for the USB port has a serial defect, which has not been corrected.
                    "ALL WILL BE WELL" The battle cry that most inspires me to follow, from the DC's Comic character that I admire the most. And I feel satisfied with being better every day, and with using Gnu-Linux as my usual Operating System.Apologies for my English, it's not my mother tongue and I'm helping the translator.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      I find the better the quality of the usb stick and sd card the better also make sure all firmware is up to date
                      Regards Mark
                      • COPIERMAN
                        • Jun 2009
                        • 559
                        I deal with off lease copiers. First thing I do is upgrade firmware on copier once I know that overall copier is working properly.
                        • Brianneoe
                          • May 2015
                          • 322
                          Look at the connection on the USB slot. I had a customer who used the USB port all the time because they wanted to print color from their MAC but did not have the PS option. Over time they flatten down the connector pins so it did not connect. Took it apart and reformed the pins and it worked.
                          Good luck
