Ricoh MP C5000 Printer Prints Envelopes in Wrong Orientation
  • craigp
    • Jan 2018
    • 34
    I have an amazing MP C5000 copier that I really love. But when Im trying to print envelope it always prints in wrong orientation. I have tried a lot but I somehow am unable to figure out how to get this machine to print in correct orientation.
    Video:
    Paper Setting:
    Printing from Word:
    • 37429
    Re: Ricoh MP C5000 Printer Prints Envelopes in Wrong Orientation
    I have no idea what you are trying to set through WIM but it wrong.
    1. The bypass tray needs to be set to use Program/Command instead of Machine Setting. This is usually done through User Tools -- Printer
    2. In Printer Properties the bypass tray paper size needs to be set to Com 10 Env.
    3. In envelop printing the paper source needs to be set to Bypass
    • craigp
      • Jan 2018
      • 34
      Thank you for your reply!
      As seen here in this new video settings are not possible to set Com 10 Env in this machine:
      1. Bypass tray is already set to use Driver/Command Settings https://f002.backblazeb2.com/file/ra...3_00-32-55.png
      2. Do not have Com 10 Env on this ricoh printer
      3. Envelope Printer paper source is set to bypass. https://f002.backblazeb2.com/file/ra...3_00-34-13.png
        • 37429
        Com 10 Env is set in the print driver properties not the physical printer.
        If it is not there, you are using the wrong driver. The correct driver is the current PCL 6 Driver. And not anything for Universal Print.
          +1
          • craigp
            • Jan 2018
            • 34
            Thank you again for your response. Today I have tried these settings and somehow this is still problematic for me.
            1. I've set Bypass Tray setting to Envelope # 10
            2. Printer Driver I assume Im using correctly as well:
            3. Printing Output is still the same as before:
            • davel
              • Oct 2011
              • 1099
              Use driver PCL6 for MP C5000, not universal. Not sure but try DL envelope or is C5 the correct size.
              • craigp
                • Jan 2018
                • 34
                Tried with new printer driver:
                Com10
                Still having the same sideways printing issue as earlier.
                • craigp
                  • Jan 2018
                  • 34
                  Any ideas guys?
                    • 37429
                    Spend a little money and contact a Ricoh Family Group dealer in your area and have them send a customer trainer out to show you what to do.
                    • JaysOnTheEDGE
                      • 61
                      Can you change the orientation of the envelope in the bypass tray and try it that way to LEF?
                      the XANTE impressia envelope printer was basically a RICOH SPC820DN (the printer version of the C5000) Print Engine with a with a input/ouput belt system to feed the envelopes but it ran in LEF mode
                      • craigp
                        • Jan 2018
                        • 34
                        the XANTE impressia envelope printer was basically a RICOH SPC820DN (the printer version of the C5000) Print Engine with a with a input/output belt system to feed the envelopes but it ran in LEF mode
                        I will try this tomorrow. I've been just really scared of paper being jammed if I try to put the envelope in wrong orientation. But looks like that would be the last resort here.
                        • JaysOnTheEDGE
                          • 61
                          Here are some more idea's try bypassing the label and envelope wizard in MS Word altogether. Just make a blank document the same size as the envelope size your printing on or find a template. This also allows you the freedom to save as .PDF type file and try it in a different program like Acrobat Reader DC or something.
                          • ThePomqueteer
                            • Sep 2016
                            • 73
                            I would try changing the feed orientation (the little icon next to the preview of your envelope on Word) it looks incorrect based on how you're putting the envelope in (it should be face down I think). Sometimes you just need to experiment with that setting. The way Microsoft Word does envelopes can be confusing at best when it comes to printing in the correct orientation.
                            • dalewb74
                              • Feb 2018
                              • 1142
                              what software are you printing from? are the envelope settings set correctly in the software?
