Ricoh mpc 3001 with lcd screen not lighting up just various red and green indicators
  • Copyme
    • Jul 2020
    • 15
    [Dead] Ricoh mpc 3001 with lcd screen not lighting up just various red and green indicators
    Has anyone out there come across these symptoms? I'd be grateful for your suggestions.Thanks
  • 8T2
    • Aug 2015
    • 257
    Re: Ricoh mpc 3001 with lcd screen not lighting up just various red and green indicat
    I'd try another print controller first
    Sent from my WAS-LX1 using Tapatalk
      • 37558
      If you can access WIM see if there is an SC 202 polygon mirror motor error. You can also shine a flashlight at an angle across the display. Polygon mirror motor failure has taken out the BICU. Replace both the polygon mirror motor and BICU at the same time.
      • Copyme
        • Jul 2020
        • 15
        [QUOTE=8T2;1534388]I'd try another print controller first
        Hi there
        Thanks but I have since had it confirmed that it is probably the BICU board and Polygon mirror by someone who has had this before.Cheers
        • Copyme
          • Jul 2020
          • 15
          Hi there
          Thanks for that .someone else told me the same thing so im sure you are right.
          I did not want to take it from a working machine though so I am trying to get that one going, but it says insert cyan and magenta photoconductors even when I change the drums. any ideas on this one my friend? Hope you dont mind answering again or shall I post it seperately?
          • Polarbear
            • Feb 2012
            • 1070
            Originally posted by Copyme
            Hi there
            Hi CopyMe.
            Have you changed the polygon and BICU yet? If so check all the connectors to make sure all are connected correctly.
            Press the GREEN button!!
            • Copyme
              • Jul 2020
              • 15
              Originally posted by Polarbear
              Hi CopyMe.
              Hi Polar bear, I have no BICU or Polygon so I started on another mpc3001 but this machine says insert cyan and magenta photoconductors even when I change the drums. any ideas on this one my friend? I have tried other drums and cleaned the connector at the back.
              • mrwho
                Major Asshole!
                • 4299
                You can't post about two different machines with different symptoms on the same thread.
                One thread - One machine!
                Mascan42
                Ibid
