IS there any setting on a SP 5210 sr that i am missing to do mixed ADF sizes
  • fshead
    • 2376
    hi
    Is there a setting so the sp 5210sr can feed both letter and legal and switch paper trays?
    Also when scanning mixed sizes?
    5127 [APS Mode]*CTL [0: Not disabled/ 1: Disabled]001 This program disables the APS.
    is aps auto paper select?
    5195 [Limitless SW] DFU ?
    • 37533
    Re: IS there any setting on a SP 5210 sr that i am missing to do mixed ADF sizes
    From the copy function screen you should be able to set for mixed originals.
    • fshead
      • 2376
      hi
      i dont see that
      only batch..
      no auto paper select
      • sandmanmac
        • 3981
        Firmware:
        RTB.pdf
        Then on the copy screen/ scanner touch you'll have the option available under "original type" and select "mixed sizes".
        BTW...same for the MP301 and a couple other units i think
        • fshead
          • 2376
          Originally posted by sandmanmac
          Firmware:
          [ATTACH]46382[/ATTACH]
          hi sandy..
          hows things up north?
          i will check what i have for that series..
          thanks
          • fshead
            • 2376
            All FW was up to date so I messed with my shop machine that has updated FW and found SP 5076-01 TO BE the issue.
            I changed it to "1" and now get mixed originals..
            That was not even shown in my manual???
            odd
            • sandmanmac
              • 3981
              odd
              Good find , Andy.
              I was aware of that, but forgot to include that nugget in my reply
              • fshead
                • 2376
                i tried turning on APS, which i thought was AUTO PAPER SELECT but a no go doing that..
                And i will have to either have account make the change or stop there,1 hr drive away..
                I brought a bunch of sp 5210,sp5210 sr back from the dead with sc 530s and sc 820 codes that
                sat in the corner due to lack of free time...............
                since march i have a lot of free time...................
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  In training manual it says not available
                  Regards Mark
                  • fshead
                    • 2376
                    Originally posted by mga
                    in training manual it says not available
                    i just did it with my shop machine..legal and letter in one run..
                      • 37533
                      Training manual was printed long before the firmware update that sandy mentioned came out.
                      • fshead
                        • 2376
                        it is odd i never had this issue before...
                        default is to not allow legal letter mixed feeding ..
                        I am glad it will be able to feed mixed originals
                        thanks all
                          • 37533
                          thanks all
                          Ricoh likes to change defaults occasionally. An example is the Auto Release of Address when scanning. The default used to be OFF. Then with Cxx02 model line they changed it to ON. Of course they didn't let anyone know about the change in advance. So if you had customers who were used to walking up to the MFP with multiple documents that they wanted to scan separately but to the same folder or email address, within a day or two after delivering a new machine you got a call from the customer and had to call tech support to find out how to change it.
                          • fshead
                            • 2376
                            Could be worse issues with these machines...
                            For what i need they serve their purpose..
