Error SC541
  • Gab
    • Aug 2015
    • 671
    Error SC541
    Error 541 and 542 at aficio 1022 (i know , i know it is too old etc but too little copies made and replace it is out of question). I mesured thermofuses and lamps are ok. I replaced both thermistors it worked for a little but after few days the same. I replaced again thermistors but the same. I replaced whole fusing unit from an other working machine but after few days thermistors were out of order.
    Any idea what damages thermistors? Can it be power supply?
  • Codex
    • May 2008
    • 701
    Re: Error SC541
    Hello
    Toner is original?... Hot roller original?.... Had same problem years ago with Aficio 2045...non OEM hot roller... Where a bit thicker than original, causing Sc542. Check also the connector for the fusing unit, are the screws worn out?.... Check if the machine is connected directly to the wall outlet.
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
    • Polarbear
      • Feb 2012
      • 1070
      Re: Error SC541
      Originally posted by Codex
      Hello
      Agreed.
      The 1022 used a h/r with a thinner wall than the 220 it replaced. There were ribs inside the h/r to give it shape, but it could heat up faster because the walls of the h/r were thinner.
      On the codes - question to the OP: Is the machine in a very cold area? Does the code pop up in the early morning when attempting to use the device? Might be worth looking at a setting i remember that used to preheat the fuser if it worked in a very cold area.
      Press the GREEN button!!
      • TonerMunkeh
        Professional Moron
        • 3865
        Re: Error SC541
        Could also be the lugs that hold the hot roller bearings in place are broken, if they are, fit a set of Adonis bearings, no need to replace the frame then.
        Hit it.
          • 37444
          Re: Error SC541
          Originally posted by Polarbear
          Agreed.
          You're thinking of SC 103 Fusing Idling Use 2 to prevent SC542 from occurring at power-on. NOTE: Use SBCU firmware ver. 3.23 or newer. If the machine is not at the required firmware level be aware that the 1022 does not use SD cards for firmware updates. It uses 4MB PCMCIA cards. To write the update to the PCMCIA cards you have to use Memory Card Explorer for RICOH (MCERICOH) on a computer that has a PCMCIA I slot.
