Windows update
  • mikadonovan
    • May 2008
    • 2931
    Windows update
    Just a FYI, I lost some data on the last Microsoft Win 10 update (thankfully I had a backup), and I just noticed that ALL of the printers in the office had been changed from a standard IP port to a WSD port. I noticed it because I could not access finisher functions on one of them. Thanks to Microsoft, at least 3 hours over the last 10 days have been dedicated to fixing things they fu&!ed up. That pisses me off. Rant over.
    NEVER ASSUME ANYTHING
  • anothertech
    • 1762
    Re: Windows update
    Go in to WIM and turn off WSD, it's listed under Security. Then Windows won't change it to WSD anymore.
    • mikadonovan
      • May 2008
      • 2931
      Re: Windows update
      By golly, that's going to save me a lot of time, thank you. I'm gonna give you a rep bump.
      • Codex
        • May 2008
        • 701
        Re: Windows update
        Turn off WSD in the machine, but your customers can't print with ricoh connector anymore if you use this app
        Inviato dal mio SM-G935F utilizzando Tapatalk
        Memento Audere Semper
        • skinnyb
          • Jul 2008
          • 291
          Re: Windows update
          I do this on install now, every time. WSD is terrible.
          Sent from my LM-V405 using Tapatalk
          • sandmanmac
            • 3979
            Re: Windows update
            This is incorrect.
            Disable WSD on every single one of my machines is one of the FIRST things I do, and Connector App works fine
            • Codex
              • May 2008
              • 701
              Re: Windows update
              Originally posted by sandmanmac
              This is incorrect.
              Sorry... You're right.... I think i confused something....
              • keithxxiii
                Just a tech
                • Nov 2014
                • 468
                Re: Windows update
                What happens if you disable WSD Print and Scan only?
                Aye! Cut the crap
                • tsbservice
                  Field tech
                  • 7982
                  Re: Windows update
                  I'm glad on our KonicaMinoltas WSD Print and Scan are disabled by default
                    • 8146
                    Re: Windows update
                    On a Toshiba copier, when Windows 10 performs an automatic update. it replaces the installed Toshiba Universal 2 print driver with a Microsoft designed V4 driver.
                    This V4 driver both looks different but also causes all kinds of print issues like PDFs not printing properly.
                    I disable "Turn on automatic setup of network connected devices" found under Control Panel/ Network & Sharing/ Private/ Network Discovery
                    • sandmanmac
                      • 3979
                      Re: Windows update
                      This is what I used to do before I figured out the whole WSD thing, but it always seemed that the next Windows Update would re-enable "automatic setup....." that's what caused me to look for a more permanent solution.
                      Has that changed?
                        • 8146
                        Re: Windows update
                        Has that changed?
                        I have never had a call back for print driver issues converted to the V4 driver once I disabled Automatic setup.
                        I have seen printer drivers redirected to WSD ports when I first arrive.
                        I try and install TeamViewer wherever I go to minimize travel time on issues like this.
                          • 37378
                          Re: Windows update
                          Has that changed?
                          That is why it is always best to disable WSD on the MFP when prepping for install. One MFP vs however many computers the customer may have.
                          • tsbservice
                            Field tech
                            • 7982
                            Re: Windows update
                            Exactly Slim.
