Ricoh c751 compatible toner
  • pnai
    • Jan 2020
    • 26
    Hello
    I want to ask if any of the ricoh users use a compatible toner with the Pro c751 , I'm afraid to use not original cartridge and make any damage in my machines the only reason I want to use is the price of the original cartridge.
    Re: Ricoh c751 compatible toner
    Originally posted by pnai
    Hello
    compatible ( non-genuine /oem toner) are CRAP and could damage your copier.
    is it worth saving a few dollars in exchange for damage to: fuser/dev units/belt and other items? $$$$$$$
    stick with OEM it is designed for your machine
      • 37495
      In addition to potential damage to drum and developer, just because it is less expensive per box does not mean that it is less expensive to use.It may not contain as much toner. The best example I know of is from back before word processing programs and transcriptionist had to use typewriters to type reports. The radiology transcriptionist at a local Catholic hospital used an IBM Selectric. With IBM ribbons a ribbon averaged lasting just over 1 day. A new purchasing knew someone who had compatible ribbons for 25% less than IBM. It took 2 compatible ribbons to do the number of reports that an IBM ribbon would. Ended up costing more per report.
      • bojans
        • 1313
        Hello
        I have switched all my clients from Xerox to Ricoh Pro C 751 series. We have cca 15 units on the field, and using only OEM toner and other parts. Have clients that make 2 milions prints per year. I don't know prices in your country, here is cca 700EUR/CMYK set, and one client is making cca 55K SRA4 with set.
        I would try with non OEM toner and 'sacrifice' one machine to test, only if that toner would be 300USD per set.
        My experience with xerox non OEM toner, for DC 252 series and similar:
        Toner yield is less 30 percent,
        It will drain your developer after couple sets of toner, even faster if you mix OEM and non OEM toner,
        Color is not acceptable for professional customer,
        Drum and fuser life is sometimes less 60 percent,
        Etc
        One customer printed some posters, and put it on the wall. The rain fall overnight and washed almost all the color
        Original is the cheapest option.
        • pnai
          • Jan 2020
          • 26
          Thank you guys
          You are right , everything original with high price is cheaper , but where is my business in africa the one cartridge is $ 530 , only one not full set thats why im trying to get something compatible with a reasonable pricrs.
          Thanks again
          • bojans
            • 1313
            Then, your option is to import 5-10 sets.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              No matter what the compatible supplier says ie same as oem or better don't listen best to stick with oem buy cheap and you will pay the price in the long run
              Regards Mark
                Mark,
                +1
                  • 37495
                  Remember the old Fram commercials? Fram Oil Filter Commercial- 1972 - YouTube
