iIM C2000 -6000
  • senakainoki
    • Nov 2019
    • 25
    iIM C2000 -6000
    Hi,
    I have installed new IM C2000 machine. customer need to connect to network thru wireless. I have tried in operation panel i have connected to network thru wireless, But i can not do the printing/scanning. As per the IM C2000 brochure showing wireless card option. Please let me know anybody knowing this
    senaka
  • mikadonovan
    • May 2008
    • 2931
    Re: iIM C2000 -6000
    We just use an aftermarket wireless extender, which is much cheaper than the Ricoh wireless option. Connect the extender to the network, connect the extender to the machine via the cable, then set it up just like a regular install.
    NEVER ASSUME ANYTHING
    • Notrons
      • Apr 2016
      • 71
      Re: iIM C2000 -6000
      The wireless option thru the operations panel is for connecting model device for printing. It very short range and too weak to connect to normal wifi. You will either have to get Ricoh's wireless option or use a wireless extender. This is based on my personnel experiences, and what I had to do to get IMC on a wireless network.
      • senakainoki
        • Nov 2019
        • 25
        Re: iIM C2000 -6000
        Thanks for your supporting what you mention here IMC on a wireless network pls explain me. Did you try scan to SMB thru wireless
        • copier tech
          • 8192
          Re: iIM C2000 -6000
          The wifi in the panel is not designed for printing only for mobile devices & you WILL NOT be able to scan using this option.
          If you need to use wifi for printing/scanning use a range extender like the one in the link below this is the type I use they are very reliable.
          TL-WA850RE | 300Mbps Wi-Fi Range Extender | TP-Link United Kingdom
          • senakainoki
            • Nov 2019
            • 25
            Re: iIM C2000 -6000
            Thanks for quick response
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Re: iIM C2000 -6000
              Hi,
              senaka
              I believe the smart panel WiFi isn't for printing and scanning for use for apps etc best to hard wire into wireless router or you can buy a wireless option from ricoh but they are rubbish.
              Regards Mark
